Full Version: 2.8.2 CMD version TV Show Issue
Since updating to 2.8.2, the CMD version is not updating or scraping TV shows. It sees the qty of shows in the database but does not update or scrape new Shows/episodes.
I have tried numerous methods to remedy this:
Initialize database
remove and re-add source
clean version in new folder
latest 2.8.2 nightly
All methods show the same outcome.
2.8.1 works as expected. 2.8.2 does not.
As I run this from a scheduled task every 2 hours, I have had to revert back to 2.8.1 and live with the 20 second delay.
what I am running is -update -scrapeNew
Here is the log:
Quote:2016-07-23 00:38:09,580 INFO [main] org.tinymediamanager.TinyMediaManager:151 - =====================================================
2016-07-23 00:38:09,595 INFO [main] org.tinymediamanager.TinyMediaManager:152 - tmm.version : 2.8.2
2016-07-23 00:38:09,595 INFO [main] org.tinymediamanager.TinyMediaManager:155 - tmm.supporter : THANKS FOR DONATING - ALL FEATURES UNLOCKED Smile
2016-07-23 00:38:09,624 INFO [main] org.tinymediamanager.TinyMediaManager:158 - os.name : Windows 10
2016-07-23 00:38:09,624 INFO [main] org.tinymediamanager.TinyMediaManager:159 - os.version : 10.0
2016-07-23 00:38:09,624 INFO [main] org.tinymediamanager.TinyMediaManager:160 - os.arch : amd64
2016-07-23 00:38:09,639 INFO [main] org.tinymediamanager.TinyMediaManager:162 - java.version : 1.8.0_91
2016-07-23 00:38:09,655 INFO [main] org.tinymediamanager.TinyMediaManager:522 - default encoding : UTF-8 | UTF8 | UTF-8
2016-07-23 00:38:09,671 INFO [main] org.tinymediamanager.TinyMediaManager:522 - set encoding to : UTF-8 | UTF8 | UTF-8
2016-07-23 00:38:09,671 INFO [main] org.tinymediamanager.TinyMediaManager:187 - System language : en_AU
2016-07-23 00:38:09,686 INFO [main] org.tinymediamanager.TinyMediaManager:188 - GUI language : en_US
2016-07-23 00:38:09,702 INFO [main] org.tinymediamanager.TinyMediaManager:189 - Scraper language : English
2016-07-23 00:38:09,709 INFO [main] org.tinymediamanager.TinyMediaManager:190 - TV Scraper lang : English
2016-07-23 00:38:09,717 DEBUG [headless] org.tinymediamanager.TinyMediaManager:203 - starting without GUI...
2016-07-23 00:38:09,764 ERROR [headless] org.tinymediamanager.UpgradeTasks:340 - Could not update CMD TMM!
2016-07-23 00:38:09,780 DEBUG [headless] org.tinymediamanager.TinyMediaManager:235 - no splash found
2016-07-23 00:38:09,796 INFO [headless] org.tinymediamanager.TinyMediaManager:238 - =====================================================
2016-07-23 00:38:09,796 INFO [headless] org.tinymediamanager.TinyMediaManager:243 - starting tinyMediaManager
2016-07-23 00:38:09,814 DEBUG [headless] o.t.thirdparty.MediaInfoUtils:65 - Loading native mediainfo lib from: native/windows-x64
2016-07-23 00:38:09,896 INFO [headless] o.t.thirdparty.MediaInfoUtils:74 - Using MediaInfoLib - v0.7.85
2016-07-23 00:38:10,582 INFO [headless] o.tinymediamanager.core.movie.MovieList:326 - found 647 movies in database
2016-07-23 00:38:10,597 INFO [headless] o.tinymediamanager.core.movie.MovieList:346 - found 91 movieSets in database
2016-07-23 00:38:11,480 INFO [headless] o.t.core.tvshow.TvShowList:281 - found 201 TV shows in database
2016-07-23 00:38:12,498 INFO [headless] o.t.core.tvshow.TvShowList:311 - found 13899 episodes in database
2016-07-23 00:38:13,017 DEBUG [headless] o.t.scraper.util.PluginManager:61 - loading external plugins...
2016-07-23 00:38:13,114 WARN [headless] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data\scraper_fanarttv.conf' - using defaults
2016-07-23 00:38:13,173 WARN [headless] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data\scraper_imdb.conf' - using defaults
2016-07-23 00:38:13,189 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:284 - searching for Kodi commons
2016-07-23 00:38:13,305 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:363 - Found common: C:\Program Files (x86)\Kodi\addons\metadata.common.allmusic.com\allmusic.xml
2016-07-23 00:38:13,305 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:363 - Found common: C:\Program Files (x86)\Kodi\addons\metadata.common.fanart.tv\fanarttv.xml
2016-07-23 00:38:13,342 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:363 - Found common: C:\Program Files (x86)\Kodi\addons\metadata.common.htbackdrops.com\htbackdrops.xml
2016-07-23 00:38:13,358 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:363 - Found common: C:\Program Files (x86)\Kodi\addons\metadata.common.imdb.com\imdb.xml
2016-07-23 00:38:13,374 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:363 - Found common: C:\Program Files (x86)\Kodi\addons\metadata.common.musicbrainz.org\musicbrainz.xml
2016-07-23 00:38:13,405 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:363 - Found common: C:\Program Files (x86)\Kodi\addons\metadata.common.theaudiodb.com\tadb.xml
2016-07-23 00:38:13,405 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:363 - Found common: C:\Program Files (x86)\Kodi\addons\metadata.common.themoviedb.org\tmdb.xml
2016-07-23 00:38:13,443 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:214 - searching for Kodi scrapers
2016-07-23 00:38:13,458 WARN [headless] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data\scraper_metadata.album.universal.conf' - using defaults
2016-07-23 00:38:13,474 WARN [headless] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data\scraper_metadata.artists.universal.conf' - using defaults
2016-07-23 00:38:13,505 WARN [headless] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data\scraper_metadata.themoviedb.org.conf' - using defaults
2016-07-23 00:38:13,543 WARN [headless] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data\scraper_metadata.tvdb.com.conf' - using defaults
2016-07-23 00:38:13,574 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:248 - Found scraper: C:\Program Files (x86)\Kodi\addons\metadata.album.universal\albumuniversal.xml
2016-07-23 00:38:13,574 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:248 - Found scraper: C:\Program Files (x86)\Kodi\addons\metadata.artists.universal\artistuniversal.xml
2016-07-23 00:38:13,605 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:248 - Found scraper: C:\Program Files (x86)\Kodi\addons\metadata.themoviedb.org\tmdb.xml
2016-07-23 00:38:13,628 DEBUG [headless] o.tinymediamanager.scraper.kodi.KodiUtil:248 - Found scraper: C:\Program Files (x86)\Kodi\addons\metadata.tvdb.com\tvdb.xml
2016-07-23 00:38:13,744 WARN [headless] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data\scraper_opensubtitles.conf' - using defaults
2016-07-23 00:38:13,859 WARN [headless] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data\scraper_tmdb.conf' - using defaults
2016-07-23 00:38:13,891 DEBUG [headless] o.t.scraper.util.PluginManager:72 - Done loading external plugins - took 00:00:00.871
2016-07-23 00:38:13,906 INFO [updateThread] org.tinymediamanager.core.UpdaterTask:67 - Checking for updates...
2016-07-23 00:38:13,906 DEBUG [trackEventThread] org.tinymediamanager.scraper.http.Url:232 - getting https://ssl.google-analytics.com/collect...9200093906
2016-07-23 00:38:13,924 DEBUG [updateThread] org.tinymediamanager.scraper.http.Url:232 - getting http://release.tinymediamanager.org/buil...9200093924
2016-07-23 00:38:14,724 INFO [updateThread] org.tinymediamanager.core.UpdaterTask:150 - Already up2date Smile
2016-07-23 00:38:14,724 INFO [updateThread] org.tinymediamanager.TinyMediaManagerCMD:242 - Commandline - scraping new movies...
2016-07-23 00:38:14,746 INFO [updateThread] org.tinymediamanager.TinyMediaManager:349 - bye bye
This shows the number of TV shows in the DB but does nothing if a new episode or a new TV show is added.
whoops - you are right!
Made a small typo...
Will be fixed in 2.8.3 (nightly already working)
Thx!
Excellent... Many thanks for your efforts
