2016-07-23, 17:28
If you start a PartyMode Playlist, Kodi always shows the Playlist View (MyMusicPlaylist.xml) after adding the 10 songs.
I tried a few skins and its always the same, is this Hard coded in kodi somehow?
I wannt to show the visualisation when starting a Party Playlist.
there is a work around to go the the visualisation when starting a Song, if you create a Custom_FullscreenEnabler.xml
but Partymode Ignores this file.
I added
to MyMusicPlaylist.xml but than you cant select the playlist view anymore for obvious reasons.
any idea for a workaround?
PS: IntegerGreaterThan(MusicPlayer.Time,1) is more annoying than helpfull for me
<window type="dialog" id="3001">
<allowoverlay>no</allowoverlay>
<onload condition="!Window.IsActive(visualisation)">FullScreen</onload>
<visible>Player.HasAudio + Skin.HasSetting(MusicAuto) + !Skin.HasSetting(Use_Startup_Playlist) + !SubString(Window(videolibrary).Property(TvTunesIsAlive),true)</visible>
<controls></controls>
</window>
I added
<onload condition="!Window.IsActive(visualisation)">ReplaceWindow(visualisation)</onload>
