Full Version: Remote app won't enable on Odroid C2 Android build ??
I have looked thru this thread and can't seem to find the answer I'm looking for so I'm looking for help here...
I have KODI loaded on a Odroid C2 with Android. This is a new build that I just finished this weekend. The KODI settings are enabled so the remote control app should work but of course it's not.
I have the remote control app working on a Windows HTPC KODI system but this other Android setup is giving me a big headache.
Anyone have a suggestion??
Anyone ??
So I solved the remote issue and it was a simple one.
I wasn't aware, but I have the KODI Client on the network with a wireless connection. When I switched from a wireless connection to a wired connection (with network cable), then I could get the Apple Kodi Kore app working.
This was all it took - just a network cable / hardwired connection.
Anyways, thanks for the help !
