2016-07-24, 14:58
So I found out that I can sync both my plex and kodi libraries when it comes to watched status using trakt.tv.
I installed and setup the add-on on kodi but I am confused as to how it works. I have set it to upgrade with a library scan however my online account at trakt.tv shows nothing under library. Is this meant to just scan anything new added after I install the add-on or is it suppose to scan my current library the way it is?
Also I am using SQL on kodi, would that make a difference with the add on?
Side note: when I try to run the add-on, I get a message saying its parsing 283 episodes, thats nowhere near the total amount of episodes that I have.
