Full Version: [MOD] Coral Theme for Amber
Pages: 1 2
Hello!
I would like to present you Coral, a new theme for Amber.
I hope you guys like it, the background are the same of my blue theme which is included as well in this version of Amber
http://www.mediafire.com/download/31k34d....2.2.8.zip
Jarvis compatible?
Yes, Jarvis compatible. It's based on the latest Amber 2.2.8
Krypton compatible?
If Amber 2.2.8 it's compatible so is this one, is 2.2.8 compatible?
Vertical menu available?
It could install this like a new theme, without overwrite the original amber?
(2016-07-26, 13:58)wargo Wrote: [ -> ]If Amber 2.2.8 it's compatible so is this one, is 2.2.8 compatible?
Last version of Amber for Krypton is 3.0.2
When i try to install this MOD arises the following error message:
The dependency on xbmc.gui version 5.10.0 could not be satisfied.
(2016-07-26, 16:21)yonahbasic Wrote: [ -> ]It could install this like a new theme, without overwrite the original amber?
the original theme is included as well, the backgrounds will be differents
I deleted my amber ver first and Installed your mod, but I got this problem, the backgrounds menus dosent appear:
https://imgur.com/PceJEI4
(2016-07-26, 17:47)yonahbasic Wrote: [ -> ]I deleted my amber ver first and Installed your mod, but I got this problem, the backgrounds menus dosent appear:
which version of Kodi are you using?
I´m using Kodi 16.1 Jarvis
Sad didn´t work for me but nice job.Really liked the skin. Thank you.
(2016-07-27, 15:22)yonahbasic Wrote: [ -> ]Sad didn´t work for me but nice job.Really liked the skin. Thank you.
Hello, can you try to go back to confluence and reinstall amber? My skin is exactly the same as the original, the only changes I do is the media folder. You can just drag and drop the file from my zip to the original.
I just try, theres have to be a problem... with the Textures.xbt you dont have in your media folder and the "images" dont know where they have to go, I think.
Pages: 1 2
