2016-07-26, 17:41
Hi.
Is it possible to send a command via JSON-RPC to select a certain menu item in an addon? For example, say there is a menu item called 'Videos', could you send a command to select 'Videos' or, if 'Videos' is the third item in the menu, send a command to select the third menu item?
