Full Version: Temp files dont get deleted
Dear sirs,
ive got the problem that the .deletedByTMM Folders wouldnt get deleted after closing TMM.
Ive got the 2.8.2 Version.
In the former versions this feature had worked perfectly.
Do i do something wrong?
yours sincerly
Sweetbeat
Do you have the "deleteTrashOnExit" checkbox checked in settings?
If yes, i would need some logfiles...
Just tested here locally - works as expected.
Yes it is checked (i hope it is the correct check box, because i got the german layout)
It is called:
temporaeres Backup Verzeichnis beim Beenden loeschen
If no, where do i find that "deleteTrashonExit ??
yours sincerly
Sweet
its correct.
then please past/upload the logfile somewhere, maybe we see something...
