2007-09-08, 11:33
Hi All it's my first post so please go easy...
I have recently had problems with new AVI's playing from my HD.
It's only on new files which play fine on my PC and disc.
They either do not start or get about 10-15mins in and then close.
Stats:
XBMC SVN 2007-06-17
PAL xbox set to NTSC using enigmah.
HD AV Pack res to 720x480 4:3. Cache 256Kb.
I realise its either my cache/cpu or resolution or the muxing of the avi's but i just need a little help...should i adjust something or remux the avi's?
I have tested the AVI's with G-Spot and it appears that the files are all okay.
Any help is greatly appreciated
Here is the log from one that wont run at all:
http://pastebin.com/m747ad28d
Stats:
XBMC SVN 2007-06-17
