Full Version: install issues with log
I am having install issues. I see stuff in the log. But not sure of what is what or what condition I need to work on first.
17:13:20 T:5668 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:13:20 T:5668 NOTICE: -----------------------------------------------------------------------
17:13:20 T:5668 NOTICE: Starting Kodi (16.1 Git:20160424-c327c53). Platform: Windows NT x86 32-bit
17:13:20 T:5668 NOTICE: Using Release Kodi x32 build
17:13:20 T:5668 NOTICE: Kodi compiled Apr 24 2016 by MSVC 180040629 for Windows NT x86 32-bit version 6.0 (0x06000000)
17:13:20 T:5668 NOTICE: Running on Gigabyte Technology Co., Ltd. GA-MA74GM-S2 with Windows Vista SP2, kernel: Windows NT x86 32-bit version 6.0
17:13:20 T:5668 NOTICE: Host CPU: AMD Athlon™ Dual Core Processor 4450e, 2 cores available
17:13:20 T:5668 NOTICE: Desktop Resolution: 1152x864 32Bit at 75Hz
17:13:20 T:5668 NOTICE: Running with restricted rights
17:13:20 T:5668 NOTICE: Aero is enabled
17:13:20 T:5668 NOTICE: special://xbmc/ is mapped to: C:\Program Files\Kodi
17:13:20 T:5668 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\Kodi
17:13:20 T:5668 NOTICE: special://masterprofile/ is mapped to: C:\Users\Dennis\AppData\Roaming\Kodi\userdata
17:13:20 T:5668 NOTICE: special://home/ is mapped to: C:\Users\Dennis\AppData\Roaming\Kodi\
17:13:20 T:5668 NOTICE: special://temp/ is mapped to: C:\Users\Dennis\AppData\Roaming\Kodi\cache
17:13:20 T:5668 NOTICE: The executable running is: C:\Program Files\Kodi\Kodi.exe
17:13:20 T:5668 NOTICE: Local hostname: Dennis-PC
17:13:20 T:5668 NOTICE: Log File is located: C:\Users\Dennis\AppData\Roaming\Kodi\kodi.log
17:13:20 T:5668 NOTICE: load settings...
17:13:20 T:5668 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
17:13:20 T:5668 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
17:13:20 T:5668 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
17:13:20 T:5668 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
17:13:20 T:5668 NOTICE: Default DVD Player: dvdplayer
17:13:20 T:5668 NOTICE: Default Video Player: dvdplayer
17:13:20 T:5668 NOTICE: Default Audio Player: paplayer
17:13:20 T:5668 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:13:20 T:5668 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
17:13:20 T:5668 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:13:20 T:5668 NOTICE: Loaded playercorefactory configuration
17:13:20 T:5668 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:13:20 T:5668 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:13:21 T:4752 NOTICE: Found 2 Lists of Devices
17:13:21 T:4752 NOTICE: Enumerated DIRECTSOUND devices:
17:13:21 T:4752 NOTICE: Device 1
17:13:21 T:4752 NOTICE: m_deviceName : {9E21B35F-5EFC-47BE-BCF5-CEAAFBDA5F26}
17:13:21 T:4752 NOTICE: m_displayName : Speakers - Speakers (Realtek High Definition Audio)
17:13:21 T:4752 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers (Realtek High Definition Audio)
17:13:21 T:4752 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:13:21 T:4752 NOTICE: m_channels : FL,FR
17:13:21 T:4752 NOTICE: m_sampleRates : 48000
17:13:21 T:4752 NOTICE: m_dataFormats : AE_FMT_FLOAT
17:13:21 T:4752 NOTICE: Device 2
17:13:21 T:4752 NOTICE: m_deviceName : default
17:13:21 T:4752 NOTICE: m_displayName : default
17:13:21 T:4752 NOTICE: Device 3
17:13:21 T:4752 NOTICE: m_deviceName : {DB6A6E98-5AE0-4E02-880D-BFBC86F713C6}
17:13:21 T:4752 NOTICE: m_displayName : SPDIF - Realtek Digital Output (Realtek High Definition Audio)
17:13:21 T:4752 NOTICE: m_displayNameExtra: DIRECTSOUND: Realtek Digital Output (Realtek High Definition Audio)
17:13:21 T:4752 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
17:13:21 T:4752 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
17:13:21 T:4752 NOTICE: Enumerated WASAPI devices:
17:13:21 T:4752 NOTICE: m_displayNameExtra: WASAPI: Speakers (Realtek High Definition Audio)
17:13:21 T:4752 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
17:13:21 T:4752 NOTICE: m_sampleRates : 192000,96000,48000,44100
17:13:21 T:4752 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
17:13:21 T:4752 NOTICE: m_displayNameExtra: WASAPI: Realtek Digital Output (Realtek High Definition Audio)
17:13:21 T:4752 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100
17:13:21 T:4752 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
17:13:21 T:5668 NOTICE: Running database version Addons20
17:13:21 T:5668 NOTICE: ADDONS: Using repository repository.xbmc.org
17:13:21 T:5668 NOTICE: Found screen: Generic PnP Monitor on ATI Radeon 2100 Graphics, adapter 0.
17:13:21 T:5668 NOTICE: Primary mode: 1152x864@ 75.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 640x480@ 73.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 800x600@ 56.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 800x600@ 70.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1024x768@ 72.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1152x864@ 70.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1280x768@ 75.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
17:13:21 T:5668 NOTICE: Additional mode: 1280x960@ 70.00 - Full Screen
17:13:22 T:5668 NOTICE: Additional mode: 1280x960@ 72.00 - Full Screen
17:13:22 T:5668 NOTICE: Additional mode: 1280x960@ 75.00 - Full Screen
17:13:22 T:5668 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
17:13:22 T:5668 NOTICE: Additional mode: 1280x1024@ 70.00 - Full Screen
17:13:22 T:5668 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
17:13:22 T:5668 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
17:13:22 T:5668 NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
17:13:22 T:5668 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
17:13:22 T:5668 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
17:13:22 T:5668 NOTICE: Checking resolution 16
17:13:22 T:5668 NOTICE: CRenderSystemDX::CreateDevice - Your video driver doesn't support DirectX 11 Video Acceleration API. Application is not be able to use hardware video processing and decoding
17:13:22 T:5668 NOTICE: Running database version Addons20
17:13:22 T:5668 NOTICE: Running database version ViewModes6
17:13:22 T:5668 NOTICE: Running database version Textures13
17:13:22 T:5668 NOTICE: Running database version MyMusic56
17:13:22 T:5668 NOTICE: Running database version MyVideos99
17:13:23 T:5668 NOTICE: Running database version TV29
17:13:23 T:5668 NOTICE: Running database version Epg11
17:13:23 T:5668 WARNING: CSkinInfo: failed to load skin settings
17:13:24 T:5668 WARNING: Previous line repeats 1 times.
17:13:24 T:5668 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:13:24 T:5668 NOTICE: ActiveAE DSP - starting
17:13:24 T:5668 NOTICE: initialize done
17:13:24 T:5668 NOTICE: Running the application...
17:13:24 T:5668 NOTICE: starting upnp client
17:13:24 T:1160 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
17:13:24 T:1160 NOTICE: UDP: Listening on port 9777
17:13:24 T:5668 ERROR: CRenderSystemDX::FinishCommandList - Failed to finish command queue.
17:13:25 T:5668 ERROR: CGUIFontTTFDX::CreateVertexBuffer - Failed to create vertex buffer.
17:13:25 T:5668 ERROR: Previous line repeats 10 times.
17:13:25 T:5668 ERROR: CRenderSystemDX::FinishCommandList - Failed to finish command queue.
17:13:44 T:5668 ERROR: Previous line repeats 22 times.
17:13:44 T:5668 ERROR: CGUIFontTTFDX::CreateVertexBuffer - Failed to create vertex buffer.
17:13:44 T:5668 ERROR: CRenderSystemDX::FinishCommandList - Failed to finish command queue.
17:13:47 T:5668 ERROR: Previous line repeats 2 times.
17:13:47 T:5668 ERROR: Unable to activate the previous window
17:13:47 T:5668 ERROR: CGUIFontTTFDX::CreateVertexBuffer - Failed to create vertex buffer.
17:13:47 T:5668 ERROR: Previous line repeats 6 times.
17:13:47 T:5668 ERROR: CRenderSystemDX::FinishCommandList - Failed to finish command queue.
17:13:58 T:5668 ERROR: Previous line repeats 12 times.
17:13:58 T:5668 ERROR: CGUIFontTTFDX::CreateVertexBuffer - Failed to create vertex buffer.
17:13:58 T:5668 ERROR: CRenderSystemDX::FinishCommandList - Failed to finish command queue.
17:13:58 T:5668 ERROR: Previous line repeats 1 times.
17:13:58 T:5668 ERROR: Previous line repeats 22 times.
17:13:58 T:5668 ERROR: Previous line repeats 26 times.
17:13:58 T:5668 ERROR: Previous line repeats 27 times.
17:13:58 T:5668 ERROR: Previous line repeats 28 times.
17:14:00 T:5668 ERROR: Previous line repeats 3850 times.
17:14:00 T:5668 ERROR: CGUIFontTTFDX::CreateVertexBuffer - Failed to create vertex buffer.
17:14:00 T:5668 ERROR: Previous line repeats 1 times.
17:14:00 T:5668 ERROR: CRenderSystemDX::FinishCommandList - Failed to finish command queue.
Could my video card be the problem? I see the message.
Try to keep logs and long lists of long code out of the forum and place them in a public past-bin and link them back to your thread.
I expect you are right with "CreateDevice - Your video driver doesn't support DirectX 11 Video Acceleration API. Application is not be able to use hardware video processing and decoding" check this thread and the links.. the quick fix is message #3 then go from there. http://forum.kodi.tv/showthread.php?tid=283352
thank you, I'm old school and when I could not find attach file, I made the wrong decision - I would like to blame the video driver Wink lol
