Full Version: TV Headend + Ubuntu 16.04
Hello community ,
Is there an easy step by step tuto for installing TvHeadend on Ubuntu 16.04 . Goal is to use it on a HTPC to watch DVB-S2 sat tv via Kodi on Ubuntu 16.04 . I am new to linux but eager to try ! So in a nutshell :my HTPC holds a TBS6902 dvb-s2 dual tuner and a TBS6922SE dvb-s2 tuner .
Thank you in advance for your kind replys .
Grtz ,
ballegd
I used this one and got it working (I'm NOT a Linux specialist)
https://tvheadend.org/projects/tvheadend...Repository
For the DVB drivers I can't give you a pointer though...
Start by installing the drivers for your card (check out TBS website), then install tvheadend (there are lots of guides on the subject).
