Full Version: Video does not start
I have some original DVD copies on a NAS as VIDEO_TS and AUDIO_TS directories.
Most of the movies play but some of the movies wont play a second time.
I am using the following software:
Running on OpenELEC (official) - Version: 5.0.2, kernel: Linux x86 64-bit version 3.17.8
Kodi compiled Feb 9 2015 by GCC 4.9.2 for Linux x86 64-bit version 3.17.8 (200968)
And this is the error log on opening of the movie
15:05:59 T:140568835385088   DEBUG: JSONRPC: Incoming request: {"jsonrpc":"2.0","method":"Player.Open","params":{"item":{"movieid":7}},"id":400}
15:05:59 T:140570149914496   DEBUG: Loading settings for smb://172.16.65.21/Movies/The Bourne Identity/VIDEO_TS/VIDEO_TS.IFO
15:05:59 T:140570149914496   DEBUG: CPlayerCoreFactory::GetPlayers(smb://172.16.65.21/Movies/The Bourne Identity/VIDEO_TS/VIDEO_TS.IFO)
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
15:05:59 T:140570149914496   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
15:05:59 T:140570149914496   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
15:05:59 T:140570149914496   DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
15:05:59 T:140570149914496   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
15:05:59 T:140570149914496   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
15:05:59 T:140570149914496   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
15:05:59 T:140570149914496   DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
15:05:59 T:140570149914496  NOTICE: DVDPlayer: Opening: smb://172.16.65.21/Movies/The Bourne Identity/VIDEO_TS/VIDEO_TS.IFO
15:05:59 T:140570149914496 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
15:05:59 T:140570149914496   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
15:05:59 T:140570149914496   DEBUG: LinuxRendererGL: Cleaning up GL resources
15:05:59 T:140570149914496   DEBUG: CLinuxRendererGL::PreInit - precision of luminance 16 is 16
15:05:59 T:140568803919616  NOTICE: Thread DVDPlayer start, auto delete: false
15:05:59 T:140568803919616  NOTICE: Creating InputStream
15:05:59 T:140568803919616   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/libdvdnav-x86_64-linux.so)
15:05:59 T:140568803919616   DEBUG: Loading: /usr/lib/kodi/system/players/dvdplayer/libdvdnav-x86_64-linux.so
15:05:59 T:140568803919616    INFO:   msg: libdvdnav: Using dvdnav version 4.2.1
15:05:59 T:140568803919616    INFO: dll_fopen - something opened the mount file, let's hope it knows what it's doing
15:05:59 T:140568803919616   DEBUG:   msg: libdvdread: Couldn't find device name.
15:05:59 T:140568803919616   DEBUG: CSMBFile::Open - opened Movies/The Bourne Identity/VIDEO_TS/VIDEO_TS.IFO, fd=10002
15:05:59 T:140568803919616   DEBUG: CSMBFile::Open - opened Movies/The Bourne Identity, fd=-1
15:05:59 T:140568803919616    INFO: SMBFile->Open: Unable to open file : 'smb://172.16.65.21/Movies/The%20Bourne%20Identity'
                                            unix_err:'15' error : 'Is a directory'
15:05:59 T:140568803919616   DEBUG:   msg: NAME OPEN FAILED
15:05:59 T:140568803919616    INFO:   msg: libdvdnav: vm: DVD Title:
15:05:59 T:140568803919616    INFO:   msg: libdvdnav: Unable to find map file '/storage/.dvdnav/.map'
15:05:59 T:140568803919616    INFO:   msg: libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions:
15:05:59 T:140568803919616    INFO:   msg:  1
15:05:59 T:140568803919616    INFO:   msg:  2
15:05:59 T:140568803919616    INFO:   msg:  3
15:05:59 T:140568803919616    INFO:   msg:  4
15:05:59 T:140568803919616    INFO:   msg:  5
15:05:59 T:140568803919616    INFO:   msg:  6
15:05:59 T:140568803919616    INFO:   msg:  7
15:05:59 T:140568803919616    INFO:   msg:  8
15:05:59 T:140568803919616   DEBUG: Open - Setting region mask ff
15:05:59 T:140568803919616  NOTICE: DVDPlayer: playing a file with menu's
15:05:59 T:140568803919616  NOTICE: Creating Demuxer
15:05:59 T:140568803919616   DEBUG: DVDNAV_HOP_CHANNEL
15:05:59 T:140568803919616   ERROR: Error getting next block: Error opening vtsN=0, domain=2.
15:05:59 T:140568803919616   DEBUG: Open - avformat_find_stream_info starting
15:05:59 T:140568803919616   DEBUG: ffmpeg[7FD8B99FC700]: [mpeg] Before avformat_find_stream_info() pos: 0 bytes read:0 seeks:0
15:05:59 T:140568803919616   DEBUG: ffmpeg[7FD8B99FC700]: [mpeg] After avformat_find_stream_info() pos: 0 bytes read:0 seeks:0 frames:0
15:05:59 T:140568803919616 WARNING: could not find codec parameters for smb://172.16.65.21/Movies/The Bourne Identity/VIDEO_TS/VIDEO_TS.IFO
15:05:59 T:140568803919616   DEBUG: Open - av_find_stream_info finished
15:05:59 T:140568803919616    INFO: ffmpeg[7FD8B99FC700]: Input #0, mpeg, from 'smb://172.16.65.21/Movies/The Bourne Identity/VIDEO_TS/VIDEO_TS.IFO':
15:05:59 T:140568803919616    INFO: ffmpeg[7FD8B99FC700]:   Duration: N/A, bitrate: N/A
15:05:59 T:140568803919616  NOTICE: Opening stream: 0 source: 512
15:05:59 T:140568803919616  NOTICE: Finding audio codec for: 0
15:05:59 T:140568803919616   DEBUG: FactoryCodec - Audio: passthrough - Opening
15:05:59 T:140568803919616   DEBUG: FactoryCodec - Audio: passthrough - Failed
15:05:59 T:140568803919616   DEBUG: FactoryCodec - Audio: FFmpeg - Opening
15:05:59 T:140568803919616   DEBUG: CDVDAudioCodecFFmpeg::Open() Unable to find codec 0
15:05:59 T:140568803919616   DEBUG: FactoryCodec - Audio: FFmpeg - Failed
15:05:59 T:140568803919616   ERROR: Unsupported audio codec
15:05:59 T:140568803919616   DEBUG: FactoryCodec - Overlay: FFmpeg Subtitle Decoder - Opening
15:05:59 T:140568803919616   DEBUG: Open - Unable to find codec 0
15:05:59 T:140568803919616   DEBUG: FactoryCodec - Overlay: FFmpeg Subtitle Decoder - Failed
15:05:59 T:140568803919616   ERROR: OpenStream - Unable to init overlay codec
15:05:59 T:140568803919616   DEBUG: OnPlayBackStarted: play state was 1, starting 1
15:05:59 T:140568803919616   DEBUG: CDVDPlayer::SetCaching - caching state 3
15:05:59 T:140568803919616 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
15:05:59 T:140568803919616 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
15:05:59 T:140570149914496   DEBUG: PlayFile: OpenFile succeed, play state 2
15:05:59 T:140570149914496   DEBUG: OnPlayBackStarted: play state was 2, starting 0
15:05:59 T:140568803919616   DEBUG: CDVDPlayer::SetCaching - caching state 0
15:05:59 T:140568803919616  NOTICE: CDVDPlayer::OnExit()
15:05:59 T:140568803919616  NOTICE: DVDPlayer: eof, waiting for queues to empty
15:05:59 T:140568803919616   DEBUG: CSMBFile::Close closing fd 10002
15:05:59 T:140568803919616   DEBUG: OnPlayBackEnded: play state was 2, starting 0
15:05:59 T:140568803919616   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
15:05:59 T:140568803919616   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
15:05:59 T:140568803919616   DEBUG: Thread DVDPlayer 140568803919616 terminating
15:05:59 T:140570149914496   DEBUG: CGUIInfoManager::SetCurrentMovie(smb://172.16.65.21/Movies/The Bourne Identity/VIDEO_TS/VIDEO_TS.IFO)
15:05:59 T:140570149914496   DEBUG: GetMovieId (smb://172.16.65.21/Movies/The Bourne Identity/VIDEO_TS/VIDEO_TS.IFO), query = select idMovie from movie where idFile=7
15:05:59 T:140570149914496   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
15:05:59 T:140570149914496   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
15:05:59 T:140570149914496   DEBUG: UPnP: Building didl for object 'smb://172.16.65.21/Movies/The Bourne Identity/VIDEO_TS/VIDEO_TS.IFO'
15:05:59 T:140570149914496 WARNING: Platinum [platinum.core.statevariable]: Invalid value of 0 for state variable TransportPlaySpeed
15:05:59 T:140570149914496 WARNING: Platinum [platinum.core.statevariable]: Allowed: 1
15:05:59 T:140570149914496  NOTICE: CDVDPlayer::CloseFile()
15:05:59 T:140570149914496  NOTICE: DVDPlayer: waiting for threads to exit
15:05:59 T:140570149914496  NOTICE: DVDPlayer: finished waiting
15:06:00 T:140569873860352  NOTICE: service.libraryautoupdate-0.9.8 : Skipping scan, only run when idle
15:06:30 T:140570149914496  NOTICE: Previous line repeats 1 times.
15:06:30 T:140570149914496   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/libdvdnav-x86_64-linux.so)
15:06:30 T:140570149914496   DEBUG: Unloading: /libdvdnav-x86_64-linux.so
What I understand is that the movie stops because the speed is 0, but I never send this command.
