Full Version: VPN on Kodi
I have entered the VPN details from my provider into the VPN settings of Kodi. However, it will not connect. I have checked the settings a number of times, and checked with my provider: Private Internet Access. I have it set on PPTP. I am wondering if there is something else that I should have activated or maybe downloaded another App to get this feature to work. Any ideas? Thanks
This isn't a Kodi issue.
I don't understand. I am using ONLY Kodi to enter the VPN settings, and no Apps. Surely this makes it a Kodi issue?
It sounds like you are using a VPN add-on. Kodi has no native VPN settings.
