Full Version: KODI freeze on "Quit" with Aeon Nox Skin
Hello!
I have installed the latest Aeon Nox skin on KODI on my Android (5.1) TV Box (Himedia Q10 Pro). All seemed right, except when I trying to "Quit" from the System menu the whole KODI freezes and won't Quit (or Exit), lke it should do with this command. I still can "Quit"Huh with the "Home" button on my Box's remote and get back to the Launcher's main screen, but it would be mutch peasant and restful to Quit from KODI with it's built in, official method.
Any one else experienced this kind of bug with the Aeon Nox Skin or is this some kind of unique case? Or could it be some incompatibility with my TV Box?
I would like to lay down, that with the KODI default skin the "Exit" command works flawlessly, and never found such of "Freezing" at all.
Thanks for the replies!
This might be a bug indeed. Try changing the quit menu action to
Quit()
in the submenu editor.
This will be fixed for next version.
(2016-07-30, 13:12)BigNoid Wrote: [ -> ]This might be a bug indeed. Try changing the quit menu action to
Quit()
Ok, thanks, will have a try then and report if it works or not!
