Full Version: Ability to return to live position on channel
One feature that would be awesome to add (and would really help the WFA) would be the ability to catch back up to live TV on the PVR.
The way i see this working is :
Pause the TV for 15/20 minutes (or any amount of time), start watching TV by pressing play, rather than having to skip/big skip / fast forward through the time shifted channel, press X button(to be defined / mapped) to get back to live TV.
Some things that would need to be set able would be :
Ability to map the function to a button (keyboard or remote)
Ensure any forced buffering (from advanced settings) is adhered to
An example of this on non-kodi is sky in the UK, if you have time shifted pressing the stop button once resumes live, pressing it again stops the channel.
I would value others feedback on the idea and most importantly the feedback of the development team to say if it's achievable
Phil
Sent from my Nexus 6P
@MOD - please move this to the relevant area if this is not the correct section - thanks Smile
