Hi there. I did a search on this forum for intro movie with transparency skin. And from what I can tell, there is no support for this feature. Is that correct and is it something that is possible to add on my own with a quick code patch? Transparency is the best skin in my opinion and this would be an awesome feature since it's a pretty graphical skin.
indeed no support for intro movies in T!
don't know about your coding skills, so don't ask me if you're capable of adding it yourself ;-)
you could edit the Startup.xml in your ...skin.transparency\1080p\ folder and add the Line: <onload>PlayMedia(e:\Path_to_your_intro\introkodi.mkv)</onload>
But keep in mind that on every skinupdate this setting is gone...
I know its "quick and dirty" but it worked for me
Thanks michael I shall try that
