I'm wondering if we will be able to instal any of the other skin.
You can install any skin that supports Kodi 17.
ok , I was thinking that all the skins that appear in the get more section , but I guess that's not the case
All the skins that appear in the Get More section when you have Kodi 17 installed are supported.
Ok it must be my device because only a few actually install ill try again .
Thread moved to OS independent
(2016-08-02, 02:05)natethomas Wrote: [ -> ]All the skins that appear in the Get More section when you have Kodi 17 installed are supported.
not if you have custom repos enabled that hold only incompatible skins.
