Full Version: Nvidia Shield TV - Crash with Canadian Broadcast Company (CBC) video add-on
Wanted to watch the 2016 Olympics (in Canada) on my [/code] and noticed there was a video add-on for CBC (which is perfect), it installed fine but when I try to start it I am told there are errors and to look at the log file and there are a bunch of errors - honestly was hoping someone could take a look and see if a fix is possible...
18:59:47 T:1458555184   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.AttributeError'>
                                            Error Contents: 'NoneType' object has no attribute 'group'
                                              File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.cbc/default.py", line 12, in <module>
                                                ma.processAddonEvent()
                                              File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.t1mlib/lib/t1mlib.py", line 209, in processAddonEvent
                                                if mode==  None:  self.procDir(self.getAddonMenu,    p('url'), 'files', 'default_view')
                                              File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.t1mlib/lib/t1mlib.py", line 156, in procDir
                                                ilist = dirFunc(url, ilist)
                                              File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.cbc/resources/lib/scraper.py", line 28, in getAddonMenu
                                                html = re.compile('<section class="section-cats full">(.+?)</section>', re.DOTALL).search(html).group(1)
                                            AttributeError: 'NoneType' object has no attribute 'group'
18:59:48 T:1391139120   ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting plugin://plugin.video.cbc/
18:59:48 T:1391139120   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.cbc/) failed
19:00:05 T:1435494704   ERROR: EXCEPTION: Non-Existent Control 1
19:00:09 T:1436539184 WARNING: Attempt to use invalid handle -1
19:01:08 T:1487874352 WARNING: Previous line repeats 2 times.
19:01:08 T:1487874352   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
19:01:08 T:1391139120   ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting plugin://plugin.video.cbc/
19:01:08 T:1391139120   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.cbc/) failed
And it just goes on-and-on (if you want the entire trace just let me know how best to send it).
Thanks,
