Full Version: 'Live TV' menu option not showing?
Running Kodi 16.1 on FireTV
LIVE TV menu item never shows for real PVR add-ons, it only shows when the Demo PVR add-on is enabled and NO other PVR add-on is enabled. Soon as I enable any other add-on, poof, no more LIVE TV menu item?
... I've tried enabling one or multiple PVR add-ons.
... Live TV is "enabled" under Settings -> Live-TV -> General
... I deleted TV29.db & Epg11.db
Everything else in Kodi works perfect.
Anyone seen this issue - or know how to fix? Thx
Which PVR add-on are you enabling? Have you disabled the Demo before enabling your addon? Have you configured your addon before enabling it? Is your backend properly configured and running, and accessible from its own frontend?
figured it out. It was a permissions issue with the WMC client.
http://forum.kodi.tv/showthread.php?tid=280458
