(2017-02-20, 15:18)3000 Wrote: [ -> ]Yes, VDR 2.2.0. I am using a dvb-s2 twin tuner card.
The epg that I get is insufficient. This is why I try to make the xml work in vdr. But it is very complicated.
I will have a look and ask over there too, thanks!
I think easiest would be if I could make my backend work under the IPTV Simple Client, but I don't think that will be possible.
It's a hassle ...
Have a look if it will work with tvheadend. You can definitely import an xmltv file there.
thank you, I will have a look.
Keep up your good work! It's highly appreciated!
Hi. Hopefully someone can help me to generate xml and ini file for astro.com.my coz i running kodi on android box. Thanks
(2017-02-22, 15:58)shamcheani Wrote: [ -> ]Hi. Hopefully someone can help me to generate xml and ini file for astro.com.my coz i running kodi on android box. Thanks
You probably won't be able to run the Webgrab exe on Android. No-one has found a way to get it to run so far.
It will work on LibreELEC, Windows, Linux or maybe OSX.
I tried astro.com.my on Windows. I added Animal Planet and it worked fine without any extra configuration steps.
Some tv guide sources need cookie files to be set up. There will be a text file in the site.ini folder with instructions if needed.
Hey primaeval,
Just getting some errors when trying to 'Import WebGrab++.config.xml' on one of the latest nightlies - any chance you are able to test? Have tried on OS X and Windows but same errors on both.
12:03:10.534 T:123145377017856 NOTICE: [xbmcswift2] Request for "/download_ini_pack" matches rule for function "download_ini_pack"
12:03:10.536 T:123145377017856 ERROR: GetDirectory - Error getting /Users/xxx/Library/Application Support/Kodi/userdata/addon_data/script.webgrab/webgrab/siteini.pack
12:03:10.536 T:123145377017856 ERROR: GetDirectory - Error getting special://profile/addon_data/script.webgrab/webgrab/siteini.pack
12:03:41.172 T:140736105255872 ERROR: GetDirectory - Error getting plugin://script.webgrab/download_ini_pack
12:03:41.172 T:140736105255872 ERROR: CGUIMediaWindow::GetDirectory(plugin://script.webgrab/download_ini_pack) failed
12:03:45.266 T:123145375408128 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value
12:03:45.267 T:123145375408128 NOTICE: [xbmcswift2] Request for "/import_config" matches rule for function "import_config"
12:03:54.247 T:123145375408128 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'NoneType' object has no attribute 'group'
File "/Users/xxx/Library/Application Support/Kodi/addons/script.webgrab/main.py", line 1452, in <module>
plugin.run()
File "/Users/xxx/Library/Application Support/Kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 332, in run
items = self._dispatch(self.request.path)
File "/Users/xxx/Library/Application Support/Kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 306, in _dispatch
listitems = view_func(**items)
File "/Users/xxx/Library/Application Support/Kodi/addons/script.webgrab/main.py", line 1335, in import_config
site = re.search('site="(.*?)"',attributes).group(1)
AttributeError: 'NoneType' object has no attribute 'group'
12:03:54.306 T:140736105255872 ERROR: GetDirectory - Error getting plugin://script.webgrab/import_config
12:03:54.306 T:140736105255872 ERROR: CGUIMediaWindow::GetDirectory(plugin://script.webgrab/import_config) failed
(2017-02-23, 03:39)twghughes Wrote: [ -> ]Hey primaeval,
plugin.run()
Send me a link to the config file. It looks like the site field can't be read.
Find the file here:
https://cl.ly/3L3p2z2Y340b
If I can assist I am happy to, just not sure where to look - fairly new to WG++ and all!
Edit: Now that you mention the 'site' field being an issue - is this likely to be a problem with my SD backup channels? I guess I can remove them, import the file and add them back later if that's the case.
Cheers
(2017-02-23, 08:49)twghughes Wrote: [ -> ]Find the file here:
Cheers
It is all the ones with the same_as field.
<channel offset="0" same_as="BBC ONE HD" xmltv_id="BBC ONE SD">BBC ONE SD</channel>
The addon only parses standard channel definitions with site attributes like:
<channel update="i" site="radiotimes.com" site_id="94" xmltv_id="BBC ONE HD">BBC ONE HD</channel>
(2017-02-23, 09:55)primaeval Wrote: [ -> ]It is all the ones with the same_as field.
Ah, interesting. Would it be possible to get it to parse these? I know these days a lot of us have various "+1" channels in our listings so these are likely to crop up a lot.
(2017-02-23, 10:58)martinconroy Wrote: [ -> ] (2017-02-23, 09:55)primaeval Wrote: [ -> ]It is all the ones with the same_as field.
I don't think I have the energy to do that. It is quite a big change to link channels together.
If anyone wants to add the changes in I'll add it to the repo.
for all of you who works with webgrab+plus for windows there is an nice tool you can free download and use.
http://www.manyplay.de
xmlgrabplus for windows
mo editing of any xml file anymore...
primaeval
hmm - did you not find the xmlgrabplus on the site?
(2017-03-16, 11:37)bitcue Wrote: [ -> ]@primaeval
I take it back. Sorry. It is a good tool. I would recommend it.
The web site is too hard to read unless you live in a cave all day. Only for vampires.
The only main things missing that this addon can do is the cookie generation for tv.com and directv.com, renaming and sorting channels.
