hello. iwould like to do a coverflow like menu in Home.xml is this possible. it should be. can someone point me in the right direction. im using coverflow from xboxclassic in the rest of the skin.
rock on / ERIK
Yes, it is possible.
Just dump the same code in, add a list container and specify some static content for it.
As per usual, the online manual has the info you need. See Vision for examples of static content lists.
jmarshall Wrote:Yes, it is possible.
And xTV these days which is probably a better example because it also uses outside images for animation
tnx . i figured out the static list and the wraplist ting. but cant get the 3d stuff to show.
