2016-08-09, 12:41
Hi, I've had a weird OS crash on my Windows 2012 R2 KODI setup with MySQL and I need to reinstall. It appears I've been able to save all files however since I cannot boot up the original OS installation I cannot perform a clean SQL backup. So I basically need some tips ASAP so I can start reinstalling my OS, install KODI & MySQL - then hopefully reimport my database without having to redo everything. I've put a lot of effort into the database.
Brief info:
So basically I would much, much appreciate if I could get some input on how to proceed after having reinstalled OS & setup KODI with MySQL again to get my old database imported - if possible. Here is a screenshot of my programdata\MySQL\MySQL Server 5.6\data folder:
https://s10.postimg.org/3ntzj7neh/mysql_...mbilde.jpg
All help appreciated. Badly want my KODI and server back up&running ASAP. Awaiting to see if I get some feedback here before reinstalling in case there is something I need to examine on the old OS harddrive before reformatting.
In advance, thank you!
Brief info:
- I used to have a single profile when I first setup MySQL
- Later added a second profile ("Maria") which left me with "master user" + "maria" profiles on startup
- It appears I have both MySQL 5.5 & MySQL 5.6 on the harddrive. Honestly don't recall why or if I upgraded at some point
- When checking my programdata\MySQL\MySQL Server 5.5\data there is not much content, so apparently the 5.6 version was what I was using
- programdata\MySQL\MySQL Server 5.6\data has a lot of folders, but I have no clue which ones are valid. I.e. on music I have "mymusic52", "mymusic56", "mastermusic52", "mariamusic52" & "mariamusic56"
- I remember having some issues during upgrade to 16.0 I think, which I believe is what caused the multiple 52, 56 etc folders
