I have Asus eee pc and Linux 17.3 on it and when i updated Kodi to version 17 (Krypton beta) it runs reealy slow when i had version 16.1 or older it worked great. How i get older linux versions of Kodi because in respositories there are only 17 version.
See
this thread for some more details on switching between beta and stable sources.
When i try to add unstable respository i have it:
add-apt-repository ppa:team-kodi/unstable
'To PPA nie obs\xc5\x82uguje trusty'
Nie można dodać prywatnego archiwum pakietów: „'To PPA nie obs\xc5\x82uguje trusty'”
Unstable is the beta (Krypton v17).
If you want to go back to stable (Jarvis) try the following under root (sudo):
apt-get remove kodi kodi-bin
add-apt-repository -r team-xbmc/unstable
apt-get install kodi
If you need to add it, the stable repo is team-xbmc/ppa - see
Official Ubuntu PPA (wiki)
It installed Krypton v17 bete but it runs great. Thanks! You may close this thread.
