2016-08-30, 23:50
Pages: 1 2
2016-08-30, 23:57
2016-08-30 17:55:50 Error parsing 5789b551-6f17-4958-b2fc-1a15f6b425ac.mobileprovision
2016-08-30 17:55:51 Error parsing 5bd2789f-bfb0-4034-8345-1b48e44f0771.mobileprovision
2016-08-30 17:55:51 Found 0 Provisioning Profiles
2016-08-30 17:55:51 Found 4 Codesigning Certificates
2016-08-30 17:55:51 Added signing certificate "iPhone Developer: ju*****[email protected] (4KRC54AH5Y)"
2016-08-30 17:55:51 Added signing certificate "Mac Developer: ju*****[email protected] (4KRC54AH5Y)"
2016-08-30 17:55:51 Added signing certificate "iPhone Developer: er*****[email protected] (QL2FN2Q62W)"
2016-08-30 17:55:51 Loaded Codesigning Certificate from Defaults: iPhone Developer: ju*****[email protected] (4KRC54AH5Y)
2016-08-30 17:55:51 Ready
2016-08-30 17:56:22 Error parsing 5bd2789f-bfb0-4034-8345-1b48e44f0771.mobileprovision
2016-08-30 17:56:22 Invalid provisioning profile
2016-08-31, 19:24
(2016-08-30, 23:57)PhantomGrey Wrote: [ -> ]2016-08-30 17:55:50 Error parsing 5789b551-6f17-4958-b2fc-1a15f6b425ac.mobileprovision
What version of Xcode / Mac OS are you running?
Would you mind uploading those provisioning files so I can analyze them?
2016-08-31, 22:11
(2016-08-31, 19:24)DanTheMan827 Wrote: [ -> ](2016-08-30, 23:57)PhantomGrey Wrote: [ -> ]2016-08-30 17:55:50 Error parsing 5789b551-6f17-4958-b2fc-1a15f6b425ac.mobileprovision
Mac 10.12 sierra and Xcode 7.2
2016-08-31, 22:12
(2016-08-31, 22:11)PhantomGrey Wrote: [ -> ](2016-08-31, 19:24)DanTheMan827 Wrote: [ -> ](2016-08-30, 23:57)PhantomGrey Wrote: [ -> ]2016-08-30 17:55:50 Error parsing 5789b551-6f17-4958-b2fc-1a15f6b425ac.mobileprovision
I'm assuming the latest preview release?
2016-08-31, 22:16
Not really sure... I got all the downloads from your page... the Xcode and the app signer... the Mac is on beta
2016-09-01, 00:51
(2016-08-31, 22:12)DanTheMan827 Wrote: [ -> ](2016-08-31, 22:11)PhantomGrey Wrote: [ -> ](2016-08-31, 19:24)DanTheMan827 Wrote: [ -> ]What version of Xcode / Mac OS are you running?
2016-09-01, 18:29
(2016-09-01, 00:51)PhantomGrey Wrote: [ -> ](2016-08-31, 22:12)DanTheMan827 Wrote: [ -> ](2016-08-31, 22:11)PhantomGrey Wrote: [ -> ]Mac 10.12 sierra and Xcode 7.2
Yeah, I was referring to the Mac OS Sierra release
Does software update show any newer version of Mac OS?
Are you using the developer beta or the public beta?
Just trying to ascertain which build of Sierra you're running
2016-09-01, 18:33
(2016-09-01, 18:29)DanTheMan827 Wrote: [ -> ](2016-09-01, 00:51)PhantomGrey Wrote: [ -> ](2016-08-31, 22:12)DanTheMan827 Wrote: [ -> ]I'm assuming the latest preview release?
No it's on 10 beta 7
2016-09-04, 01:35
So, there appears to have been a slight change in the profile format...
It seems to mostly be the same but I still have a little work to do
2016-09-04, 02:10
(2016-09-04, 01:35)DanTheMan827 Wrote: [ -> ]So, there appears to have been a slight change in the profile format...
Ok
2016-09-06, 20:08
(2016-09-04, 02:10)PhantomGrey Wrote: [ -> ](2016-09-04, 01:35)DanTheMan827 Wrote: [ -> ]So, there appears to have been a slight change in the profile format...
Ok
Okay, so I updated the app and tested on 10.12 developer beta 8 and it works
Could you please try the newest version (1.8.3) and see if that works?
If not, could you please open Terminal and in the following command and post the output?
security cms -D -v -i <path to the provisioning profile>
2016-09-07, 05:04
Worked perfectly thank you
2017-04-19, 00:48
YES DAN THE MAN THIS ONE HAS PLAGUED ME EVERYTIME I COME TO SETUP! Thank God I found the post!!!
Open Finder and delete everything in this folder ~/Library/MobileDevice/Provisioning Profiles
Pages: 1 2
