Hi, I tried several setting but hope anybodycan advise, I used Kodi 16+, now I am since 2 month's using 17+
Nvidia Shield Android TV, Plus Sony UHD TV.
problem is that since I switched to version 17 (tried all betas and alphas) all my movies on HDD are more or less buffering
while in the same configuration I didn't have this problems with Kodi 16+. I like 17+ and the new interface.
Question is how to solve this? Is it a matter of settings? Is this a common problem?
Bob
Bob,
How are you serving the local media from your HDD?
Thanks,
don't quite understand what you mean, local media?
I only use my media privatly.
Bob
(2016-08-12, 16:43)Quadro Wrote: [ -> ]Thanks,
Bob
"Serving local media"... that's what I mean, your own private media.. how are you serving it to KODI? SMB, NAS, NFS, etc.....
for some reason my last post dissapeared.
I am using external HDD's through USB3.0, my extra external memory is a SSD, also through USB 3.0, I have the Shield without the internal HDD.
In the meantime I continued testing, now the latest 17+ also refuses to play my 3D movies, for my SONY UHD, I have to switch the Shield to 1080P,
but after starting a 3D movie , Kodi forces the Shield to 4K, so no 3D anymore.
Than I removed Kodi 17+ the latest nightly, and installed version 16.1 , than my stuttering and buffering of my movies was dissapeared and my 3D worked also again.
So I wonder what is changed in the 17+ versions (I tried all), instead of improofments, I have only additional problems.
BTW I used the 17+ , because I like the new interface
Understood, so you are only getting this problem in 17.1 correct? If that's the case, share a debug log when it exhibits the problem and maybe the devs can find out what's causing it and work on a fix in case its a global issue and not a single user related issue.
Why kodi 17.0 don't support "Screen Syncronisation" and passtrough like kodi 16.0?
if a audioformat linke acc or mp3 has no passtrough so it bildschirm syncro works and no "Ruckler" in the NFL GP.
WHamilton Not trying to be rude, but what does your question have to do with the OPs original question? You should start a new thread with your question, unless it relates to the OPs. Thanks.
