2018-07-11, 11:53
2018-08-19, 16:46
Does 4k streaming work with sport events? I've no kodi box to test this yet
2018-08-20, 21:57
(2018-08-19, 16:46)prynn Wrote: [ -> ]Does 4k streaming work with sport events?Yes.
2018-09-12, 09:37
This works so great with all audio and video! Thanks to bad it can't be done with Netflix above 720p.
2018-09-30, 04:02
Would it be possible to create an addon like this for TV 2 Sumo in Norway. Sport streams are encrypted. I think they use Fairplay. They use DASH for Chrome.
2018-10-05, 14:30
Hello!
I have raspberry pi 3 and libreelec installed.
I do not get the viaplay to work. When I enter a movie, it will not play. Can anybody help me?Appreciate.
Sry for my bad english
Log file https://paste.kodi.tv/zufuvagole.kodi
2018-10-05, 16:06
Posted log file over here now Hope someone can help me
And here again log file: https://paste.kodi.tv/zufuvagole.kodi
2018-10-08, 19:51
No one who wants to help me?
2018-10-11, 02:04
2018-10-11, 10:23
Please post a complete log file. Which version of Kodi/Libreelec?
/D
/D
2018-11-16, 04:24
Updated my S912 Amlogic box to the newest CoreELEC today 8.95.4.3. With that it also updated Inputstream Helper to 0.3.3.
Viaplay addon stopped working. Videos doesn’t start.
Does anyone know if it compatible with the latest version, or do I have to roll back?
If i’m the only one I can provide logs
2019-01-09, 13:03
Hi There,
Iv just downloaded Viaplay Video add on to my KODI app on my TV. Using Firestick.
Viaplay app is visible and I can go through the menus and there are images but when I click through to watch anything there is on audio or video.
What do I to fix? Can this be fixed?
Lea123
Lea123
2019-01-13, 14:36
I'd like to script commands using the web interface, such as using the kodijson module requesting RPC JSON commands.
print(kodi.Addons.ExecuteAddon(addonid="plugin.video.viaplay", ...
I'd like to be able to get the Directory Listings and also start playing a selected Items. Anyone knows how that can be achieved?
2019-01-30, 03:10
So are there a guide how to get this to work?
I installed Kodi 18 and then the addon and InputStream Adaptive. Tried to watch an NHL game got prompted to install Widevine wich I did and then tried again but the "Working..." down in the right just flash a few times and the nothing more.
What else do I have to do for it to work?
I usually manage to figure stuff like this out but this addon has been my nemesis since day one
2019-03-02, 22:15
I just stumbled upon this add-on today and I have to say it's great. Thanks for the awesome work!
@emilsvennesson I have a few questions I hope you can answer.
I'm using the Embuary skin and I've added widgets on the home screen and in the skin's TV shows hub. The widgets are populated with content from the add-on.
Everything works as it should when playing content via the widget on the home screen, but for some reason there are issues with the same widget in the TV shows hub.
Here is a video to illustrate the issue:
Do you have any idea why it's prompting me to re-authenticate every time I'm playing content via the widget in the TV shows hub?
Sometimes you don't even have to press play from the TV shows hub, you just have to enter the hub and go back to the home screen and it will ask you for the single use-code when you press play on the widget there. It seems like stuff gets broken just by entering the TV shows hub...
I asked for help in the Embuary forum thread and the creator of the skin suggested it might have something to do with the path that is used and that I should ask here for help...
Also, take a look at the screenshots below.
The first is taken when I start playback from the widgets I've set up. The second is taken when playing content from within the add-on.
If you compare the first screenshot to the second one, you can see that the title of the TV programme is missing from the top left and bottom.
The thumbnail isn't showing either. Is there any way to fix this? Again, the creator of Embuary said this is probably something you would have to look into.
Quote: "The dev has to fix it on his end and fill the listitem properties correctly from a widget playback approach."
I would really appreciate if you look into this
