Full Version: Found a Bandcamp Addon and it works
Pages: 1 2 3
Great man, it works here. I can finally listen to my collection. Thanks!!
I can't get this to work (only search function works). Is anyone using it currently?
(2020-01-28, 12:56)Jackojmi Wrote: [ -> ]I can't get this to work (only search function works). Is anyone using it currently?
do you have an premium account? only search works if you didnt bought anything there, so it is not supposed to show up nothing.
(2020-01-30, 16:42)Norin_Radd Wrote: [ -> ]
Yes I have premium account (as in I have bought many albums on this account, is this what you mean?).
EDIT: logs below (I'm having issues with pasting logs the normal way, hence the Gdrive link)
https://drive.google.com/open?id=1pxc7e_...oS2wROY8zg
(2019-06-11, 18:59)peat Wrote: [ -> ]Try this updated version:
https://github.com/peat80/kodi-bandcamp
Atleast the collection should work again.
And the language files are now in the newer format compatible with latest kodi matrix builds.
@Jackojmi
have you tried @peat version, as i have explained, iam not the dev.
(2020-02-21, 03:31)Norin_Radd Wrote: [ -> ]
@Jackojmi
Thanks fir the reply-- yeah I'm on that version, for some reason mine not working.
Im going to go down Yatse remote "send to kodi" from bandcamp and see if I can get that working.
Hi there,
Any luck with yatse?
I'm in the same boat, Kodi 18.6 on Xbox one.
(I'm not a paying bandcamp subscriber)
Only way I play anything is by going through the search route.
Greatful for the efforts in creating a script though! Thanks!
(2020-03-21, 18:08)PantsOnFire Wrote: [ -> ]Hi there,
I haven't got around to doing a log etc in Yatse yet. Have been meaning to but this working from home situation is flat out for me. If youre interested here is the thread. The dev I think will be helpful if logs etc are submitted, he has been in my experience.
https://community.yatse.tv/t/send-to-kod...dcamp/2389
Otherwise I'll get round to eventually.
FYI bandcamp has no real subscriber model, it's more of a store that you can stream before you buy. To have an account just needs 1 purchase I think
Created the brand new plugin for bandcamp:
https://forum.kodi.tv/showthread.php?tid=354190
Please check it out and share your opinion
I'm not sure if there is s a new thread for this addon, but it works really well! I use it regularly to listen to my collection and especially for the "wishlist" area.
Also very useful is the integration with yatse remote, I can cast albums from the phone app.
Thanks for all the work on it.
Edit I have seen the new thread, right above my own post 🤦
Pages: 1 2 3
