Full Version: HEVC 1080p playback "pixellation"
Apologies if this has already been posted. My problem is this: when I play HEVC 1080p video, I get a sort of large square pixellation. See this screenshot below for an example:
It's most evident in two sort of diagonal zig-zags to the left and right of screen. On closer inspection it appears the entire screen is pixellated. This problem only occurs at 1080p - 720p HEVC plays fine in Kodi. Also, I have no problems in VLC, it plays 1080p HEVC fine on the same machine with no issues. I'm running an Intel i3 6100 with no GPU.
Please verify with a nightly version of v17. Try with DXVA enabled/disabled.
(2016-08-12, 07:16)FernetMenta Wrote: [ -> ]Please verify with a nightly version of v17. Try with DXVA enabled/disabled.
Just tried the Aug 12 nightly. Problem still present, tried all methods of video processing.
Did you try with software decoding, means DXVA hw acceleration disabled?
(2016-08-12, 18:50)FernetMenta Wrote: [ -> ]Did you try with software decoding, means DXVA hw acceleration disabled?
That seems to have fixed it. I just hope video playback will be smooth. Thanks!
Hi Vinay92,
i had the same problem a few weeks ago. It could be solved by a great tip from fritsch.
Just look here: http://forum.kodi.tv/showthread.php?tid=278799
Michael
