2017-09-11, 00:09
2018-08-31, 16:47
Hi Jin,
I've installed your addon and logged in. After that, I can navigate between menus and select the sport video I want to play. The problem is when I play it, the screen comes all white... looks like kodi can't decode the image. DO you know what I am doing wrong?
Thanks,
Thanks,
2018-08-31, 17:07
Sounds like your (android?) device can not play hd widevine protected content. Go to dazn's addon settings - video player - inputstream adaptive settings and limit the resolution to either 480p or 720p
2018-08-31, 17:19
Thanks for the quick reply.
I've tried putting 480p on the max resolution ofor both general and secure decoders but it did not fix the issue.
I'm using a fire tv stick.
Any other setting I should play with? for example:
- override HDCP status?
- compatibility mode?
Thanks,
Thanks,
2018-08-31, 17:22
Are you using kodi 18? If not get the latest nightly (from today), otherwise it will probably crash.
If you are still having issues please post a full debug log.
2018-08-31, 17:23
I'm still on kodi 17. let me try to update it first then
2018-08-31, 17:41
It works now!
Updated to latest kode and reset settings to default...
thank you!
thank you!
2018-09-12, 17:19
I have installed some widgets from the DAZN submenus. Now everytime I start Kodi I get networ problem error popups from the DAZN addon. Like 4-5 of them, probably from every widget. The widget show no content. After a while they do, probably after a retry login attempt from the addon.
Maybe the addon can learn to retry one or two more times before throwing out those popups or otherwise I'd like to supress those messages.
Jin, can we do that?
2018-09-12, 23:50
If you are using libreelec or similar try with 'wait for network before starting kodi' activated (https://www.youtube.com/watch?v=XoaMnUeOu48).
2018-09-13, 04:29
I am on Windows where this setting does not exist.
How about a toggle to supress the messages?
2018-09-13, 06:43
I'll see if i can somehow integrate it doing it automatically. Can you help me with a debug log please?
2018-09-13, 13:08
(2018-09-13, 06:43)JinJin Wrote: [ -> ]I'll see if i can somehow integrate it doing it automatically. Can you help me with a debug log please?The related message are:
13:44:39.442 T:6976 DEBUG: [plugin.video.dazn] error: failed to get device id (busy)
13:44:41.195 T:4680 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.dazn/?id=ComingUp¶ms=PageType%3ACompetition%3BContentType%3ACompetition%3BContentId%3A6by3h89i2eykc341oz7lv1ddd&mode=rail&title=Demn%C3%A4chst&reload==
2018-09-13, 17:50
Can you please post the full output please*. I know the response from the addon but want to know how the widgets are interacting with it.
* you can also send me a link via pm (dont post the full output here as reply)
2018-09-13, 17:54
I am also getting complete crashes of the addon. I happens without using it. Just letting Kodi run. The addon wouldn't even start anymore without updating or reinstalling it.
17:48:32.487 T:4524 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.dazn/)
17:48:32.487 T:4524 DEBUG: ParentPath = [addons://sources/video]
17:48:32.487 T:8748 DEBUG: Thread JobWorker start, auto delete: true
17:48:32.487 T:8360 DEBUG: Thread waiting start, auto delete: false
17:48:32.499 T:8748 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.dazn] took 12 ms
17:48:32.499 T:7468 DEBUG: Thread JobWorker start, auto delete: true
17:48:32.499 T:8360 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin DAZN('plugin://plugin.video.dazn/','67','','resume:false')
17:48:32.500 T:4732 DEBUG: Thread LanguageInvoker start, auto delete: false
17:48:32.500 T:4732 INFO: initializing python engine.
17:48:32.500 T:4732 DEBUG: CPythonInvoker(116, E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\addon.py): start processing
17:48:32.528 T:4732 DEBUG: -->Python Interpreter Initialized<--
17:48:32.528 T:4732 DEBUG: CPythonInvoker(116, E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\addon.py): the source file to load is "E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\addon.py"
17:48:32.529 T:4732 DEBUG: CPythonInvoker(116, E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\addon.py): setting the Python path to E:\Kodi_18B1\portable_data\addons\plugin.video.dazn;E:\Kodi_18B1\portable_data\addons\script.module.certifi\lib;E:\Kodi_18B1\portable_data\addons\script.module.chardet\lib;E:\Kodi_18B1\portable_data\addons\script.module.idna\lib;E:\Kodi_18B1\portable_data\addons\script.module.inputstreamhelper\lib;E:\Kodi_18B1\portable_data\addons\script.module.requests\lib;E:\Kodi_18B1\portable_data\addons\script.module.urllib3\lib;E:\Kodi_18B1\system\python\DLLs;E:\Kodi_18B1\system\python\Lib;E:\Kodi_18B1\python27.zip;E:\Kodi_18B1\system\python\lib\plat-win;E:\Kodi_18B1\system\python\lib\lib-tk;E:\Kodi_18B1;E:\Kodi_18B1\system\python;E:\Kodi_18B1\system\python\lib\site-packages
17:48:32.529 T:4732 DEBUG: CPythonInvoker(116, E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\addon.py): entering source directory E:\Kodi_18B1\portable_data\addons\plugin.video.dazn
17:48:32.529 T:4732 DEBUG: CPythonInvoker(116, E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\addon.py): instantiating addon using automatically obtained id of "plugin.video.dazn" dependent on version 2.25.0 of the xbmc.python api
17:48:32.587 T:4524 DEBUG: ------ Window Init (DialogBusy.xml) ------
17:48:32.770 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting definitions
17:48:32.770 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: trying to load setting definitions from old format...
17:48:32.770 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting values
17:48:32.771 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting definitions
17:48:32.771 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: trying to load setting definitions from old format...
17:48:32.772 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting values
17:48:32.772 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting definitions
17:48:32.772 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: trying to load setting definitions from old format...
17:48:32.773 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting values
17:48:32.773 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting definitions
17:48:32.773 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: trying to load setting definitions from old format...
17:48:32.774 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting values
17:48:32.774 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting definitions
17:48:32.775 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: trying to load setting definitions from old format...
17:48:32.775 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting values
17:48:32.776 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting definitions
17:48:32.776 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: trying to load setting definitions from old format...
17:48:32.776 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting values
17:48:32.777 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting definitions
17:48:32.777 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: trying to load setting definitions from old format...
17:48:32.777 T:4732 DEBUG: CAddonSettings[plugin.video.dazn]: loading setting values
17:48:32.778 T:4732 INFO: CPythonInvoker(116, E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\addon.py): script aborted
17:48:32.778 T:4732 DEBUG: CPythonInvoker::onExecutionDone(116, E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\addon.py)
17:48:32.788 T:4732 INFO: Python interpreter stopped
17:48:32.788 T:4732 DEBUG: Thread LanguageInvoker 4732 terminating
17:48:32.807 T:8360 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.dazn/
17:48:32.807 T:8360 DEBUG: Thread waiting 8360 terminating
17:48:32.807 T:4524 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
17:48:32.808 T:4524 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.dazn/) failed
and
17:55:48.660 T:5280 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.dazn/
17:55:48.675 T:4524 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.dazn/) failed
17:56:06.108 T:4524 ERROR: Window Translator: Can't find window osdaudiodspsettings
17:56:10.441 T:4524 WARNING: Trying to add unsupported control type 17
17:56:10.442 T:4524 WARNING: Previous line repeats 1 times.
17:56:10.442 T:4524 ERROR: Control has invalid animation type (no condition or no type)
17:56:15.261 T:3416 ERROR: Previous line repeats 1 times.
17:56:15.261 T:3416 ERROR: EXCEPTION: Unknown addon id 'plugin.video.dazn'.
17:56:15.263 T:3416 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.RuntimeError'>
Error Contents: Unknown addon id 'plugin.video.dazn'.
File "E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\addon.py", line 14, in <module>
addon_url=url_
File "E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\resources\lib\common.py", line 28, in __init__
addon = self.get_addon()
File "E:\Kodi_18B1\portable_data\addons\plugin.video.dazn\resources\lib\common.py", line 63, in get_addon
return xbmcaddon.Addon()
RuntimeError: Unknown addon id 'plugin.video.dazn'.
and
addon_url=url_
2019-03-31, 18:31
Hi Jin jin... can you update dazn addon... it says today error
