Full Version: Video is zoomed in
Hey,
Im using kodi 16.1 jarvis with DSplayer, LAV filters, Xysubfilters and madVR. Whenever i play a video it gets zoomed and i can only see 1/4 of the picture. If i use windowed mode it works.
Debug log: http://pastebin.com/Ldje1qU5
I have tried:
  • Fullscreen exclusive mode disabled in kodi
  • Hardware acceleration off
  • Uninstalling Reclock
Another problem im experiencing is when i open the property page for all the internal filters it doesnt show everything.
Picture: http://imgur.com/a/lkKEF
Thank you in advance guys!
with the mouse clicked in the kodi screen try pressing the / key and see if that works
(2016-08-15, 13:44)Hudson_Hawk04 Wrote: [ -> ]with the mouse clicked in the kodi screen try pressing the / key and see if that works
Nop, didnt work.
Actually try the \ key.
Oops my bad
(2016-08-16, 03:43)nickr Wrote: [ -> ]Actually try the \ key.
Thank you, it worked! But is there a fix to this problem or do i have to do this everytime i watch a video?
What version of Windows and with what hardware/GPU?
(2016-08-17, 02:12)Ned Scott Wrote: [ -> ]What version of Windows and with what hardware/GPU?
Windows pro 64bit
MB: M5A97 le r2.0
SSD: Samsung Evo 250GB
PSU: Corsair RM750
CPU: FX 6200 clocked at 4.5Ghz
GPU: GTX 970
RAM: 8GB DDR3 1600Mhz
TV: Samsung JS8500 65" (UE65JS8505)
You increase your chances for getting help if you post in the DSPlayer thread.
(2016-08-17, 09:43)FernetMenta Wrote: [ -> ]You increase your chances for getting help if you post in the DSPlayer thread.
On this forum?
(2016-08-17, 10:54)DarrenHill Wrote: [ -> ] Here
Thank you! I will post there aswell if its okey?
