Full Version: refresh estuary widgets when using smart playlists.
Hello, I've been modding estuary a bit to have two movie buttons based on smart playlists. The widgets works fine but they never update if I dont restart kodi, since I use mysql I don't do any libary scans on this computer so I would like to it to refresh on a time interval or at wakeup or something. I did the same when confluence was the default skin but it seemed confluence refreshed itself on wakeup.
Edit: On closer inspection I noticed that tv-shows widgets dont update until I restart kodi either, and tv-shows are not touched by me, is it supposed to be like that? I noticed in the log that RecentlyAddedJob did run and if you click on latest added tv shows at the top, new shows show at the top. But the widget doesnt get updated.
Much thanks for any help
after playing around playing around for a while and started a few files the menu finally updated and it works with my custom smart playlists.
So now then it seems that the widgets in krypton/estuary updates a lot less frequently then jarvis/confluence.
Is there a way to control this? or run it manually? Im 99% certain jarvis ran this on wakeup but krypton/estuary dont do this.
thanks!
Same issue as above,
Is there anyway to update the home widgets without restarting Kodi?
