Full Version: Windows10 + Kodi wont let PC Sleep
Hi Guys,
Got a couple issues regarding the title.
1. For some reason Kodi will not let my PC running Windows10 sleep (Anniversary Update). My computer lights are constantly on no matter how I adjust the sleep settings.
2. The above wouldnt even be an issue if when the computer is left on Kodi is horribly slow + choppy. Moving around through the menu is extremely laggy and then when going to play any video its unwatchable and choppy until I restart my PC
Any advice for either issue?
Much appreciated
Hardware/Software
Alienware Alpha (i3, 4gb, 1TB SSD)
Win 10 Anniversary update
Kodi 16.1
*I believe all drivers and everything are up to date but open to any feedback on how to ensure this
I had the same problem, went back to Windows 8. In My case i think there are no new drivers for some components and only standard drivers.
You could try this:
to determine what program is keeping your system from sleeping:
Run cmd.exe with administrative privileges (this is key, powercfg will run under anything, but will give incorrect results)Run powercfg -requests to get a listing of items currently preventing sleep
Then this
Resolution when Driver srvnet is the problem (not sure if work on WIN 10)[/B]
Issue was resolved by running following command at the elevated command prompt:
powercfg -requestsoverride "DRIVER" "srvnet" "System"
This command tells system to ignore all power requests made by srvnet[/B] driver.
To reverse the changes run following:
To view all ignored drivers and processes run:
Did you try running in windows 8 compat, mode first? win10 can run Kodi 16.1 and greater perfectly now.
