This is the log:
http://pastebin.com/24TqwmQP
I guess line 85 has to do with PVR IPTV simple client crash it says it can't find pvr.iptvsimple.so . But what can I do about it?
Please use pastebin.com for logs (paste them there and supply the URL they will give here) and remove the log above, as it's easier to read and use on Pastebin and doesn't clutter up the forum database. Also comments like "I guess line 85 has to do with PVR IPTV simple client crash ..." make no sense at all on a quoted log, except if people want to start line-counting.
Also debug logging needs to be enabled (see
debug log (wiki) for details on how to do that) with a new full log, and also the
banned add-on (wiki) repo and any add-ons on that list you may have need to be removed before support is offered here.
Lastly I'm not sure the IPTV Simple client you're using is the one built into Kodi. There are other versions around, but the default basic one is the only one we support here, not any of the forks or other variants.
Thanks, I found out that for linux I had to install the package...
But now the tv option is not there, even if enabled. what can I do?
Turn on debug logging (see
debug log (wiki)), get rid of the
banned add-on (wiki) crap and gather/upload a new clean log.
We cannot offer any support whilest banned crap is installed.
All right! Every addon that is now installed is completely originated from the kodi addon repository.
This is my kodi debugging log:
http://pastebin.com/Lpuugzcj
22:07:54 T:140347753608960 ERROR: CCurlFile::Open failed with code 404 for http://streamer.dowebhost.info:2709/get.php?username=xxxx&password=xxxxxx&type=m3u&output=mpegts
Looks like you're trying to play a file that doesn't exist. Is this a legal sources or something dodgy and fly-by-night?
I found something strange: when opening the file in epiphany browser the file is normally opened as a text file. But when I try to download it using wget I get a 404 error... I'll try to download it through epiphany and use the file:// protocol.
EDIT: But I failed...
EDIT2: I made it by using the local m3u file, but when I try to load the channels they do not load.
http://pastebin.com/qaP394cz
