2007-09-25, 17:14
I've been playing about with grouplists and trying to optimise some code. There were quite a few similar grouplists containing buttons which I am trying to combine using conditional visibility.
My problem now is that if any of the buttons are hidden then navigating through them doesn't work properly. I can scroll left no problem but if I scroll right it stops on the button before the hidden one.
An example is as follows:
Now if I'm looking at clips the two buttons with id=5 are hidden but it doesn't scroll through them left and right, only to the left.
Am I using them incorrectly or is this a bug?
<control type="grouplist">
<include>mediamenugroup</include>
<control type="button" id="2">
<label>100</label>
<include>mediamenu</include>
</control>
<control type="button" id="3">
<label>103</label>
</control>
<control type="button" id="5">
<label>Library</label>
<onclick>Skin.SetBool(movielibrary)</onclick>
<onclick>XBMC.ReplaceWindow(MyVideoLibrary,movietitles)</onclick>
<visible>Skin.HasSetting(videomovies)</visible>
</control>
<onclick>Skin.SetBool(tvlibrary)</onclick>
<onclick>XBMC.ReplaceWindow(MyVideoLibrary,tvshowtitles)</onclick>
<visible>Skin.HasSetting(videotv)</visible>
</control>
<control type="button" id="20">
<label>Setup</label>
<onclick>XBMC.ActivateWindow(myvideossettings)</onclick>
</control>
</control>
