(2017-03-10, 22:57)foleyjo Wrote: [ -> ] (2017-03-10, 20:56)blinken Wrote: [ -> ] (2017-03-10, 08:07)foleyjo Wrote: [ -> ]Try
-f -g "$ROM$"
Gave it a try. Same thing, cemu window opens but doesn't load rom. No error message or anything. The emulator just opens.
Have you got spaces in the file or directory names? If so remove them and try again
No it looks good to me. Here is the relevant bit from my log.
18:06:49.211 T:4592 ERROR: Previous line repeats 2 times.
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() Launching ROM in Launcher ...
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() Using Launcher standard arguments
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() Sigle ROM detected (no multidisc)
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() ROMFileName OP "F:\Games\WiiU\Mario Kart 8\code\Turbo.rpx"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() ROMFileName P "F:\Games\WiiU\Mario Kart 8\code\Turbo.rpx"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() categoryID 10421432946926205de434ca7e34a101
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() launcherID 50a756fc28e92880f468e7aa3ba32c94
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() romID 259c8053e7dc78c4d7cb94ee2e61092b
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() romfile "F:\Games\WiiU\Mario Kart 8\code\Turbo.rpx"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() rompath "F:\Games\WiiU\Mario Kart 8\code"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() rombase "Turbo.rpx"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() rombasenoext "Turbo"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() romtitle "Mario Kart 8"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() application "C:\1EMU\EMULATORS\cemu_1.7.2\Cemu.exe"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() apppath "C:\1EMU\EMULATORS\cemu_1.7.2"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() romext "rpx|wud"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() raw arguments "$rom$"
18:06:49.211 T:4592 ERROR: AEL INFO : _command_run_rom() final arguments "F:\Games\WiiU\Mario Kart 8\code\Turbo.rpx"
18:06:49.221 T:4592 ERROR: AEL INFO : fs_write_Favourites_JSON() File special://profile/addon_data\plugin.program.advanced.emulator.launcher\most_played.json
18:06:49.223 T:4592 ERROR: AEL INFO : _command_run_rom() Launcher is not Kodi Retroplayer.
