2017-07-30, 16:08
I gave up. Went back to the other rom program. Maybe one if his next releases will fix it somehow. Doesn't work in windows or ubuntu when scanning wii files.
(2017-03-19, 23:51)Darksmile Wrote: [ -> ]Hello,
When I use AEL in Kodi Krypton, the game is launched and I can play but Kodi remains active: my movements with the Gamepad, in game, act on the menu of Kodi !!!
Others games are launched, or movies...
I want to use AEL but i can't do it like that
Could you help me plz ?
I use Xbox One Gamepad ans aeon nox theme. Sorry for my english, i m french.
(2017-07-30, 16:08)elementalwindx Wrote: [ -> ]I gave up. Went back to the other rom program. Maybe one if his next releases will fix it somehow. Doesn't work in windows or ubuntu when scanning wii files.
(2017-07-31, 01:30)yevaman44 Wrote: [ -> ]I've got exactly the same problem with lnk ( shortuts to my pc games)
Anyway , No problem with retroarch, only with lnk pc games shortcut)
idea to fix that ?!
(2017-07-31, 06:43)elementalwindx Wrote: [ -> ]They need to make it so you can opt in to send these logs automatically to the addon developer. Like the first time an error appears perhaps. I just don't have the time to play "chase the bug" is all.
(2017-07-31, 05:49)Wintermute0110 Wrote: [ -> ](2017-07-31, 01:30)yevaman44 Wrote: [ -> ]I've got exactly the same problem with lnk ( shortuts to my pc games)
idea to fix that ?!
Try the following and report back:
1) Increase the pause before launching the application: Go to AEL addon settings, "Advanced" tab, and increase or decrease the "After/before launch delay (ms)" time.
2) Put Kodi in windowed mode before launching: go to your LNK ROM launcher, open the context menu, "Edit Launcher", "Advanced Modifications", then turn ON "Toggle Kodi into Windowed mode"
First try 1), if doesn't work try 2), if doesn't work try both and report result back.
(2017-08-03, 11:58)Pahapaavali Wrote: [ -> ]Hello!
Could someone help me to make a launcher for linux navigation program called navit in ael? I don't know which platform to choose for a linux program, the option "unknown" doesn't work in this case.
(2017-07-31, 09:29)yevaman44 Wrote: [ -> ](2017-07-31, 05:49)Wintermute0110 Wrote: [ -> ](2017-07-31, 01:30)yevaman44 Wrote: [ -> ]I've got exactly the same problem with lnk ( shortuts to my pc games)
idea to fix that ?!
Just try both this morning.
I had considerably incarced to delay (4000)
Same problem with the two solution.
Thx for trying to help !
(2017-08-03, 14:25)yevaman44 Wrote: [ -> ](2017-07-31, 09:29)yevaman44 Wrote: [ -> ](2017-07-31, 05:49)Wintermute0110 Wrote: [ -> ]Try the following and report back:
Any other idea to fix the problem ?
(2017-08-03, 13:01)Wintermute0110 Wrote: [ -> ](2017-08-03, 11:58)Pahapaavali Wrote: [ -> ]Hello!
Can you please elaborate? To launch navit I guess you need to create an Standalone Launcher. Setting the platform to "Unknown" should be OK.
(2017-07-31, 01:30)yevaman44 Wrote: [ -> ]Hello,
(2017-08-04, 02:55)zachmorris Wrote: [ -> ](2017-07-31, 01:30)yevaman44 Wrote: [ -> ]Hello,
I think thats an issue you can only get around currently by disabling joystick control in Kodi settings. I wanted to attempt to stop the same thing in my addon somehow but wasn't able to find a solution yet.
See here and here.
(2017-08-03, 17:23)Pahapaavali Wrote: [ -> ](2017-08-03, 13:01)Wintermute0110 Wrote: [ -> ](2017-08-03, 11:58)Pahapaavali Wrote: [ -> ]Hello!
Yes I created an Standalone Launcher and the platform as "Unknown". But when I start the navit-launcher, it doesn't do anything in "front", something happens in background because if I try to launch or do something else with ael, it says there is a launcher already running. Sorry, not a native speaker so my writing is all over the place
EDIT:
some errors in the kodi.log
18:28:07.890 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() categoryID root_category
18:28:07.891 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() launcherID 21707dc21b6bbe42db1299b82b6dbe80
18:28:07.891 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() application "/usr/bin/navit"
18:28:07.891 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() apppath "/usr/bin"
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() app_basename "navit"
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() app_ext ""
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() launcher name "navit"
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() raw arguments ""
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() final arguments ""
