2017-08-04, 17:19
(2017-08-04, 13:38)Wintermute0110 Wrote: [ -> ](2017-08-03, 17:23)Pahapaavali Wrote: [ -> ](2017-08-03, 13:01)Wintermute0110 Wrote: [ -> ]Can you please elaborate? To launch navit I guess you need to create an Standalone Launcher. Setting the platform to "Unknown" should be OK.
Yes I created an Standalone Launcher and the platform as "Unknown". But when I start the navit-launcher, it doesn't do anything in "front", something happens in background because if I try to launch or do something else with ael, it says there is a launcher already running. Sorry, not a native speaker so my writing is all over the place
EDIT:
some errors in the kodi.log
18:28:07.890 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() categoryID root_category
18:28:07.891 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() launcherID 21707dc21b6bbe42db1299b82b6dbe80
18:28:07.891 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() application "/usr/bin/navit"
18:28:07.891 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() apppath "/usr/bin"
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() app_basename "navit"
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() app_ext ""
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() launcher name "navit"
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() raw arguments ""
18:28:07.892 T:1476654000 ERROR: AEL INFO : _run_standalone_launcher() final arguments ""
That stuff you see in the log are actually not errors. It is long to explain but in order to AEL to print to the log the ERROR debug level must be activated.
If AEL prints a message like there is another instance running it is because the process navit is running. By design AEL will refuse to launch a second process until the first one has not finished. If you don't see the navit window maybe the process is running in the background. If you open a terminal and run "/usr/bin/navit" do you see a window showing up? Keep in mind that AEL is designed to run processes that create a window to run on the foreground and will not work properly with background processes or daemons.
Thanks again for answering and clearing things out!
If I write /usr/bin/navit in terminal, it opens a window for navit. For some reason it only runs in the background in AEL. Is there a way to kill the process without exiting Kodi?
EDIT:
Already found a way to kill the process.
