Full Version: kidi crashes on exit to home menu
kodi crashes (sometimes) when exiting a dialog or window to return to home menu.
i checked the end of the log following a few crashes and it always ends:
14:00:44 T:140123895351360 DEBUG: ------ Window Init (Home.xml) ------
14:00:44 T:140122167179008 ERROR: GetDirectory - Error getting
log: https://paste.ubuntu.com/23089980/
thanks in advance
does it only happen when using plugin.video.thinktv? Did you try with confluence?
Thanks for the reply,
it does not happen all the time, but happens on exit from weather, the/any system menu and addon browser. It has not happened from any view window.
1. it may or may not happen in thinktv.
2. I have not tried confluence I will give it a try soon and report back
thank you
i apologize for not trying confluence before asking for help as i should have.
sure enough all appears to be good to go in confluence.
i also tried an original mod of the skin and all is well.
so it is an issue with this mod only.
thanks again
