Just got a Fire TV, installed Kodi, installed a couple of the video channels (Crackler and PyTV), however when I try to watch anything on these channels, I get an error in the bottom right that sames "something happened, check the logs". I have no idea where event logs are kept. When I try to connect to an external File System source, I get a "could not access network" message, so I'm assuming the issues the video apps are encountering is the network also.
Fire TV is hardwired into my router and Netflix/games/etc all work fine, but Kodi isn't able to access the network it seems.
Any thoughts?
Kodi 16.1/Jarvis on Fire TV Box
edit: BUT.... when I selected to download a new skin for Kodi, it was able to download and install.... not sure if these skins are included in the distro or if they truly were "downloaded" from an external source.
I just read the Android FAQs, and it gave the location of the logfiles, but they're in a .kodi directory which doesn't appear in the Kodi File Manager. Is there a setting somewhere to make it do an ls -la so hidden directories are visible? Or can I SSH into the Fire TV or something?
edit: ohhhhhhhhhhhh..... I'm gonna have to pull the SD card and mount it on a computer to view the logs, aren't I?
Check this link
Log file/Easy (wiki)
Follow the steps and post the log link in this thread.
http://paste.ubuntu.com/23091098/
Example which is representative:
18:42:36 T:18446744072310900416 DEBUG: -->Python Interpreter Initialized<--
18:42:36 T:18446744072310900416 DEBUG: CPythonInvoker(4, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.crackler/default.py): the source file to load is "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.crackler/default.py"
18:42:36 T:18446744072310900416 DEBUG: CPythonInvoker(4, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.crackler/default.py): setting the Python path to /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.crackler:/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.common.plugin.cache/lib:/:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.6/lib/python2.6/lib-dynload
18:42:36 T:18446744072310900416 DEBUG: CPythonInvoker(4, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.crackler/default.py): entering source directory /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.crackler
18:42:36 T:18446744072310900416 DEBUG: CPythonInvoker(4, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.crackler/default.py): instantiating addon using automatically obtained id of "plugin.video.crackler" dependent on version 2.14.0 of the xbmc.python api
18:42:37 T:18446744072291158416 DEBUG: ------ Window Init (DialogBusy.xml) ------
18:42:37 T:18446744072310900416 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('v_id',)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.crackler/default.py", line 194, in <module>
jsonurl = urllib2.urlopen(channel_detail_url % (args_ar['v_id'][0]))
KeyError: ('v_id',)
18:42:37 T:18446744072291158416 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
18:42:37 T:18446744072310900416 INFO: Python script stopped
And a PyTV one:
18:42:58 T:18446744072311465456 DEBUG: [xbmcswift2] Handling incoming request for /latest
18:42:58 T:18446744072311465456 NOTICE: [xbmcswift2] Request for "/latest" matches rule for function "show_latest"
18:42:58 T:18446744072311465456 DEBUG: [plugin.video.pyvideo] HTTP request: http://pyvideo.org/api/v2/video//?ordering=-added
18:42:58 T:18446744072311465456 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: No JSON object could be decoded
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.pyvideo/addon.py", line 110, in <module>
plugin.run()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 332, in run
items = self._dispatch(self.request.path)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 306, in _dispatch
listitems = view_func(**items)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.pyvideo/addon.py", line 74, in show_latest
videos = pyvideo.get_latest()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.pyvideo/resources/lib/pyvideo.py", line 106, in get_latest
items = get_json(API_VIDEO_URL + '/?ordering=-added')
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.pyvideo/resources/lib/pyvideo.py", line 54, in get_json
return response.json()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/models.py", line 808, in json
return complexjson.loads(self.text, **kwargs)
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/json/__init__.py", line 307, in loads
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/json/decoder.py", line 319, in decode
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/json/decoder.py", line 338, in raw_decode
ValueError: No JSON object could be decoded
18:42:58 T:18446744072291158416 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
18:42:58 T:18446744072311465456 INFO: Python script stopped
Kodi does have a working network connection. I looked this up and it sounds like the issue with Crackler is the add-on author is requiring python 2.7, even though python 2.6 must be used for Kodi v16. I'm not sure if that is the same issue with the other add-on. One possible option is to use Kodi v17 Beta, which will work with Crackler.
(2016-08-26, 02:11)Ned Scott Wrote: [ -> ]Kodi does have a working network connection. I looked this up and it sounds like the issue with Crackler is the add-on author is requiring python 2.7, even though python 2.6 must be used for Kodi v16. I'm not sure if that is the same issue with the other add-on. One possible option is to use Kodi v17 Beta, which will work with Crackler.
LOL. Ran into a similar issue requesting a cloud server at work. RHEL's 'yum' requires Py 2.6, but any sort of new tools requires 2.7+ (for pip)
I'll load up Kodi 17 and see how it goes.
Thanks. v.17 works perfectly.
PyVideo still doesn't work though (but I was able to install and use a "questionable" add-on. wink-wink, nudge-nudge).
Posted the PyVideo issue here:
http://forum.kodi.tv/showthread.php?tid=291650
Again, thanks for the great support.
