Full Version: WARNING: No information found for item
I have many items that arn't included in by database, the logs says;
11:39:52 18.866798 T:1811936160 WARNING: No information found for item 'nfs://192.168.0.10/c/BarnFilmer/Astrid lindgren/Astrid Lindgren - Nya Hyss Av Emil I Lönneberga/Nya.Hyss.Av.Emil.I.Lonneberga.1972.SWEDiSH.DVDRip.XviD-BETONGEN.avi', it won't be added to the library.
11:39:52 19.034348 T:1811936160 WARNING: No information found for item 'nfs://192.168.0.10/c/BarnFilmer/Astrid lindgren/Astrid Lindgren - Vi på Saltkråkan/Vi på Saltkråkan - 1x01 - En dag i juni.avi', it won't be added to the library.
11:39:52 19.122473 T:1811936160 WARNING: No information found for item 'nfs://192.168.0.10/c/BarnFilmer/Astrid lindgren/Astrid Lindgren - Vi på Saltkråkan/Vi på Saltkråkan - 1x02 - Ro, ro till Fiskeskär.avi', it won't be added to the library.
11:39:52 19.193321 T:1811936160 WARNING: No information found for item 'nfs://192.168.0.10/c/BarnFilmer/Astrid lindgren/Astrid Lindgren - Vi på Saltkråkan/Vi på Saltkråkan - 1x03 - Vilse i dimman...........
How do I solve this?
Running Jarvis 16.1 with shared Mysqldatabase
I think it's a scraping issue. Not sure though.
Did you check the name of the file and verified if it's the same as it is on thetvdb? If not, you can try changing the name of the file or create your own nfo file to help Kodi finding the correct information on the web.
I will try this and get back Smile
Particularly check that your filename cases match the information cases. I notice you've got "Astrid lindgren" rather than "Astrid Lindgren" in the subfolder names. Check spaces after/before dashes. All that sort of thing can throw the matching off. It needs to be exact.
Also, you might be better off replacing all those full stops with underscores. The system might be misinterpreting things as file extensions when they aren't
