Full Version: [SOLVED]Beta1 trying to connect to add-on repository. How to disable?
I've just installed Krypton Beta 1 in place of Alpha2. It keeps announcing:
"Kodi Add-on repository Could not connect to repository"
In the addons section, it shows a tick next to Kodi Add-on Repository, but if I select that, there's no option to disable it or to switch it off under "configure".
This wasn't happening in the previous versions. Can anyone please tell me how to stop it? Thanks.
this should be fixed in the latest nightly build of kodi.
Should be solved in beta 2. You can install current nightly version which has the fix
Thank you very much, I'm not bothered now I know it'll go away eventually Smile I'll happily live with it until I install another build.
