Full Version: setting the preferred deinterlace method broken
I'm running kodi on an Ubuntu 16.04 machine.
It's up to date per 27 aug.
cpu: intel atom D510
gpu: ION2
I'm running Krypton, today's checkout (Merge pull request #10343 from wsnipex/nvidia-cpu-load-fix 608220d)
I need to set the deinterlacing method to vdpau-bob or I get serious stuttering, but that setting has vanished into thin air.
When I set it manually in guisettings.xml, (used to be <interlacemethod>8</interlacemethod>) kodi crashes on startup.
Crashlog is here: http://pastebin.com/A4FTbjKW
Thanks in advance for looking into this and kind regards,
Tycho.
It's know and already fixed - PR will come in the next days.
Thanks, going to do that now.
While at it, I picked this one too, I like it:
https://github.com/xbmc/xbmc/pull/10325
Seems you are a good picker :-)
@fritsch @FernetMenta thanks a million, works like a charm for me.
