2016-08-28, 03:29
Installed openSUSE Tumbleweed (x64) a bit ago with Packman repo (higher priority than default repos) and updated all packages and changed available packages to Packman's. Installed Kodi; it crashes on startup (the splash screen appears, but the crash happens before reaching the main menu).
On a separate computer with the same exact setup (different CPU; same GPU), Kodi ran fine a few days ago but before I swapped the GPU to the other computer, I noticed Kodi also crashed on-startup on that computer too. I imagine some package update is causing an issue, but no idea what.
CPU: Phenom II X4
GPU: Radeon HD 2400 PRO
CPU: Phenom II X4
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sat Aug 27 21:20:22 EDT 2016
Kodi Options:
Arch: x86_64
Kernel: Linux 4.7.2-1-default #1 SMP PREEMPT Sun Aug 21 08:59:11 UTC 2016 (34ba8d6)
Release: openSUSE Tumbleweed
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/espionage724/core (2016-08-27 21:20:23.623687005 -0400)
[New LWP 25520]
[New LWP 25522]
[New LWP 25527]
[New LWP 25525]
[New LWP 25529]
[New LWP 25523]
[New LWP 25524]
[New LWP 25528]
[New LWP 25530]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Core was generated by `/usr/lib64/kodi/kodi.bin'.
Program terminated with signal SIGABRT, Aborted.
#0 0x00007f03c9569975 in raise () from /lib64/libc.so.6
[Current thread is 1 (Thread 0x7f03d1b30940 (LWP 25520))]
Thread 9 (Thread 0x7f0391fc6700 (LWP 25530)):
#0 0x00007f03c9614a1d in poll () from /lib64/libc.so.6
#1 0x000000000123cc7a in PERIPHERALS::CPeripheralBusUSB::WaitForUpdate() ()
#2 0x000000000123cd40 in PERIPHERALS::CPeripheralBusUSB::Process() ()
#3 0x00000000012c19af in CThread::Action() ()
#4 0x00000000012c1c6f in CThread::staticThread(void*) ()
#5 0x00007f03d00f4474 in start_thread () from /lib64/libpthread.so.0
#6 0x00007f03c961d3ed in clone () from /lib64/libc.so.6
Thread 8 (Thread 0x7f03938e5700 (LWP 25528)):
#0 0x00007f03d00fa448 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0
#1 0x00007f0393b2234d in CEC::CCECClient::Process() () from /usr/lib64/libcec.so.3
#2 0x00007f0393b27f23 in P8PLATFORM::CThread::ThreadHandler(void*) () from /usr/lib64/libcec.so.3
#3 0x00007f03d00f4474 in start_thread () from /lib64/libpthread.so.0
#4 0x00007f03c961d3ed in clone () from /lib64/libc.so.6
Thread 7 (Thread 0x7f03b6904700 (LWP 25524)):
#1 0x00007f03ccaaebe1 in ?? () from /usr/lib64/libpulse.so.0
#2 0x00007f03ccaa03b1 in pa_mainloop_poll () from /usr/lib64/libpulse.so.0
#3 0x00007f03ccaa0a4e in pa_mainloop_iterate () from /usr/lib64/libpulse.so.0
#4 0x00007f03ccaa0b00 in pa_mainloop_run () from /usr/lib64/libpulse.so.0
#5 0x00007f03ccaaeb29 in ?? () from /usr/lib64/libpulse.so.0
#6 0x00007f03c5bbf148 in ?? () from /usr/lib64/pulseaudio/libpulsecommon-9.0.so
#7 0x00007f03d00f4474 in start_thread () from /lib64/libpthread.so.0
#8 0x00007f03c961d3ed in clone () from /lib64/libc.so.6
Thread 6 (Thread 0x7f03b7105700 (LWP 25523)):
#0 0x00007f03d00fa087 in pthread_cond_wait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0
#1 0x00007f03ccaaf1c8 in pa_threaded_mainloop_wait () from /usr/lib64/libpulse.so.0
#2 0x0000000000a5450c in CAESinkPULSE::AddPackets(unsigned char**, unsigned int, unsigned int) ()
#3 0x0000000000a1764e in ActiveAE::CActiveAESink::OutputSamples(ActiveAE::CSampleBuffer*) ()
#4 0x0000000000a188b2 in ActiveAE::CActiveAESink::StateMachine(int, Actor::Protocol*, Actor::Message*) ()
#5 0x0000000000a193af in ActiveAE::CActiveAESink::Process() ()
#6 0x00000000012c19af in CThread::Action() ()
#7 0x00000000012c1c6f in CThread::staticThread(void*) ()
#8 0x00007f03d00f4474 in start_thread () from /lib64/libpthread.so.0
#9 0x00007f03c961d3ed in clone () from /lib64/libc.so.6
Thread 5 (Thread 0x7f03927c7700 (LWP 25529)):
#1 0x000000000123f36a in PERIPHERALS::CPeripheralBus::Process() ()
#2 0x00000000012c19af in CThread::Action() ()
#3 0x00000000012c1c6f in CThread::staticThread(void*) ()
#4 0x00007f03d00f4474 in start_thread () from /lib64/libpthread.so.0
#5 0x00007f03c961d3ed in clone () from /lib64/libc.so.6
Thread 4 (Thread 0x7f03b5eee700 (LWP 25525)):
#1 0x00000000012bfb5c in XbmcThreads::CEventGroup::wait(unsigned int) ()
#2 0x0000000000fa1de4 in ?? ()
Thread 3 (Thread 0x7f03990fd700 (LWP 25527)):
#0 0x00007f03d00fa09f in pthread_cond_wait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0
#1 0x00007f03b4e814c3 in ?? () from /usr/lib64/dri/r600_dri.so
#2 0x00007f03b4e80c07 in ?? () from /usr/lib64/dri/r600_dri.so
Thread 2 (Thread 0x7f03b3105700 (LWP 25522)):
#1 0x0000000000a157c9 in ActiveAE::CActiveAE::Process() ()
Thread 1 (Thread 0x7f03d1b30940 (LWP 25520)):
#1 0x00007f03c956ad8a in abort () from /lib64/libc.so.6
#2 0x00007f03c95a53d0 in __libc_message () from /lib64/libc.so.6
#3 0x00007f03c95aabd6 in malloc_printerr () from /lib64/libc.so.6
#4 0x00007f03c95abb9f in _int_free () from /lib64/libc.so.6
#5 0x0000000000a0a635 in ActiveAE::CActiveAE::MakeSound(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#6 0x000000000086551a in CGUIAudioManager::LoadSound(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#7 0x0000000000865f3e in CGUIAudioManager::Load() ()
#8 0x0000000000e4e647 in CApplication::LoadSkin(std::shared_ptr<ADDON::CSkinInfo> const&) ()
#9 0x0000000000e4ee21 in CApplication::LoadSkin(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#10 0x0000000000e4f3ed in CApplication::Initialize() ()
#11 0x0000000000ef3792 in XBMC_Run ()
#12 0x000000000073b4e2 in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
21:20:21 T:140155854530880 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:20:21 T:140155854530880 NOTICE: -----------------------------------------------------------------------
21:20:21 T:140155854530880 NOTICE: Starting Kodi (16.1 Git:20160424-c327c53). Platform: Linux x86 64-bit
21:20:21 T:140155854530880 NOTICE: Using Release Kodi x64 build
21:20:21 T:140155854530880 NOTICE: Kodi compiled Aug 6 2016 by GCC 6.1.1 for Linux x86 64-bit version 4.6.0 (263680)
21:20:21 T:140155854530880 NOTICE: Running on openSUSE Tumbleweed 20160825, kernel: Linux x86 64-bit version 4.7.2-1-default
21:20:21 T:140155854530880 NOTICE: FFmpeg version: 2.8.6
21:20:21 T:140155854530880 NOTICE: WARNING: unsupported ffmpeg version detected
21:20:21 T:140155854530880 NOTICE: Host CPU: AMD Phenom(tm) II X4 20 Processor, 4 cores available
21:20:21 T:140155854530880 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
21:20:21 T:140155854530880 NOTICE: special://xbmcbin/ is mapped to: /usr/lib64/kodi
21:20:21 T:140155854530880 NOTICE: special://masterprofile/ is mapped to: /home/espionage724/.kodi/userdata
21:20:21 T:140155854530880 NOTICE: special://home/ is mapped to: /home/espionage724/.kodi
21:20:21 T:140155854530880 NOTICE: special://temp/ is mapped to: /home/espionage724/.kodi/temp
21:20:21 T:140155854530880 NOTICE: The executable running is: /usr/lib64/kodi/kodi.bin
21:20:21 T:140155854530880 NOTICE: Local hostname: Oak
21:20:21 T:140155854530880 NOTICE: Log File is located: /home/espionage724/.kodi/temp/kodi.log
21:20:21 T:140155854530880 NOTICE: load settings...
21:20:21 T:140155854530880 NOTICE: Found 1 Lists of Devices
21:20:21 T:140155854530880 NOTICE: Enumerated PULSE devices:
21:20:21 T:140155854530880 NOTICE: Device 1
21:20:21 T:140155854530880 NOTICE: m_deviceName : Default
21:20:21 T:140155854530880 NOTICE: m_displayName : Default
21:20:21 T:140155854530880 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
21:20:21 T:140155854530880 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:20:21 T:140155854530880 NOTICE: m_channels : FL,FR
21:20:21 T:140155854530880 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
21:20:21 T:140155854530880 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
21:20:21 T:140155854530880 NOTICE: Device 2
21:20:21 T:140155854530880 NOTICE: m_deviceName : alsa_output.pci-0000_00_14.2.analog-stereo
21:20:21 T:140155854530880 NOTICE: m_displayName : Built-in Audio Analog Stereo
21:20:21 T:140155854530880 NOTICE: m_displayNameExtra: Line Out (PULSEAUDIO)
21:20:21 T:140155854530880 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
21:20:21 T:140155854530880 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:20:21 T:140155854530880 NOTICE: Default DVD Player: dvdplayer
21:20:21 T:140155854530880 NOTICE: Default Video Player: dvdplayer
21:20:21 T:140155854530880 NOTICE: Default Audio Player: paplayer
21:20:21 T:140155854530880 NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:20:21 T:140155854530880 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
21:20:21 T:140155854530880 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:20:21 T:140155854530880 NOTICE: Loaded playercorefactory configuration
21:20:21 T:140155854530880 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:20:21 T:140155854530880 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
01:20:21 T:140155407660800 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
01:20:21 T:140155854530880 NOTICE: Running database version Addons20
01:20:21 T:140155854530880 NOTICE: ADDONS: Using repository repository.xbmc.org
01:20:22 T:140155854530880 NOTICE: Setup SDL
01:20:22 T:140155854530880 NOTICE: Checking resolution 16
01:20:22 T:140155854530880 NOTICE: Using visual 0x2c4
01:20:22 T:140155854530880 NOTICE: GL_VENDOR = X.Org
01:20:22 T:140155854530880 NOTICE: GL_RENDERER = Gallium 0.4 on AMD RV610 (DRM 2.45.0 / 4.7.2-1-default, LLVM 3.8.0)
01:20:22 T:140155854530880 NOTICE: GL_VERSION = 3.0 Mesa 12.0.1
01:20:22 T:140155854530880 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
01:20:22 T:140155854530880 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 784312
01:20:22 T:140155854530880 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 262144
01:20:22 T:140155854530880 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_fragment_shader GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_compression_latc GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_shader_stencil_export GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_stencil_export GL_ARB_shader_texture_lod GL_ARB_texture_multisample GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_ATI_meminfo GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_base_instance GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_framebuffer_no_attachments GL_ARB_invalidate_subdata GL_ARB_program_interface_query GL_ARB_stencil_texturing GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_AMD_pinned_memory GL_ARB_buffer_storage GL_ARB_internalformat_query2 GL_ARB_multi_bind GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_stencil8 GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_NVX_gpu_memory_info GL_ARB_clip_control GL_ARB_conditional_render_inverted GL_ARB_get_texture_sub_image GL_ARB_pipeline_statistics_query GL_ARB_shader_texture_image_samples GL_ARB_texture_barrier GL_EXT_polygon_offset_clamp GL_KHR_context_flush_control
01:20:22 T:140155854530880 NOTICE: Running database version Addons20
01:20:22 T:140155854530880 NOTICE: Running database version ViewModes6
01:20:22 T:140155854530880 NOTICE: Running database version Textures13
01:20:22 T:140155854530880 NOTICE: Running database version MyMusic56
01:20:22 T:140155854530880 NOTICE: Running database version MyVideos99
01:20:22 T:140155854530880 NOTICE: Running database version TV29
01:20:22 T:140155854530880 NOTICE: Running database version Epg11
01:20:22 T:140155854530880 NOTICE: start dvd mediatype detection
01:20:22 T:140155854530880 WARNING: CSkinInfo: failed to load skin settings
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
