Full Version: CONFLUENCE SHORTCUTS
I am having issues with confluence. I have set my location and checked the show weather on homepage. I then changed the shortcuts or submenus. I am running Jarvis 16 on android box.
When I close out of Kodi the changes are lost. I have read that I should close out of Kodi with the button on the lower corner of the screen, but Kodi locks up when I do that. I am new at this, but up to this point set up was going well.
Thank you, I solved my same problem by your tip
" close out of Kodi with the button on the lower corner of the screen"
- If you on android , even if kodi looks locked you should go to android desktop. for me it worked
