Hello.
Running Kodi 16.1 ( OSMC ) with vnsi 1.11.19.
I have audio-drops seeing Live-TV ( only 5.1 ) every ca. 5 Seconds. Recording of this is ok.
Please let me know for more informations.
THX
Christian
It seems so, that deactivating "Wiedergabe mit Bildschirm synchronisieren" will help.
Do i need this option for anything ?
Did you try to set the "minvideocachelevel" and the "minaudiocachelevel" in the "advancedsettings.xml"?
If not, try it out. I also had audio drops on my odroid c2 every 45sec.
After configuring the caches everything was fine.
Greetings Hoppel
(2016-09-01, 17:19)hoppel118 Wrote: [ -> ]Did you try to set the "minvideocachelevel" and the "minaudiocachelevel" in the "advancedsettings.xml"?
Greetings Hoppel
Forget those options, I have removed those in v17.
Try v17. It is much better.
Hello FernetMenta,
ok, you removed those options, I already saw that. But if you use jarvis on your production system like me you need that buffer settings.
Without those settings I had audio drops when watching mpeg2 streams from vdr, h264 streams were fine.
I already testet to stream mpeg2 live tv from vdr with kodi 17beta1. It was really flawless.
Keep up the good work!
Greetings Hoppel
