Nice plugin, but all the titles are showing as ".divx"
Nuka1195 Wrote:Nice plugin, but all the titles are showing as ".divx"
WTF? For me, all the titles show properly. Maybe I did something wrong when I upgraded my XBMC and it doesn't work correctly with the new version? I have no other explenation for this as it works perfectly for me....Any guess, Nuka?
Workes perfect for me to rev: 23 sept
I'm just re-upgrading to the latest SVN. Maybe I messed that up. macesters comment supports my hypothesis.
Just deleted and re-copied the system folder and default.xbe. Still works though. Anything special about your installation, Nuka? Self-compiled maybe with a new addition I don't know about yet?
It really sounds like a listitem/label problem, but I can't figure out why the hell this is happening to you. The joox plugin works for you, right?
hmm, it's an october 1st build rev 10400. I'll update and see, sorry for the alarm.
no the jook, just gives me confirmed and unconfirmed, then those do not give any results. Sounds like something on my end, will investigate.
Has anything important been changed since T3CH XBMC 2007-09-30 SVN rev10387 ? Then I should find out why it does that to you because otherwise the plugin will again start to do that with the next T3CH...
Nuka1195 Wrote:no the jook, just gives me confirmed and unconfirmed, then those do not give any results. Sounds like something on my end, will investigate.
Joox is down right now: "We suffer massive server load right now, please check back in a couple of minutes."
ok it's working now, here's the scenerio. With the build i have there was an addition, the ability to run plugins from library view.
This is where divx titles are messed up. but when i added as a source in files view the title work fine. This may have been fixed in the newer svn.
Again sorry for the alarm.
Not sure why divx didn't work, but others do.
Nuka1195 Wrote:ok it's working now, here's the scenerio. With the build i have there was an addition, the ability to run plugins from library view.
Anyway, isn't this an issue we should look into?
Here is the new version with your suggested thumbnail changes:
http://max-server.informatik.uni-bremen....eFixed.rar
