2016-09-05, 10:05
I setup the autostart script as per the instructions in sections 1 and 5 here: http://kodi.wiki/view/HOW-TO:Autostart_K...emd_script. Kodi starts and stops fine when manually using systemctl start/stop/restart but upon reboot the screen goes into powersave mode and the last bit of visible output is
There are no errors in the kern.log after that
Kodi is running and responds to keyboard commands (I can exit the program, however the display is not active. The only way to get the display working is to restart kodi with `systemctl restart kodi`. Might anyone know how to fix this?
[ 2.603198] fb: switching to inteldrmfb from EFI VGA
Sep 4 19:49:53 kodi kernel: [ 2.584474] Console: switching to colour dummy device 80x25
Sep 4 19:49:53 kodi kernel: [ 2.584695] [drm] Replacing VGA console driver
Sep 4 19:49:53 kodi kernel: [ 2.591159] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Sep 4 19:49:53 kodi kernel: [ 2.591163] [drm] Driver supports precise vblank timestamp query.
Sep 4 19:49:53 kodi kernel: [ 2.600198] [drm] Finished loading i915/skl_dmc_ver1.bin (v1.26)
