Full Version: WD Wireless Pro
Hello everyone,
I have an ipad and laptop with wd external hd for my movies / tv shows. I travel alot and end up in hotels sometimes with poor wifi. That's why I have to carry my Movies / TV shows in external HD.
I want to leave my laptop behind but I have it all set up for kodi with my external HD.
I am planning to buy this Western Digital Wireless Pro (3TB)
https://www.amazon.com/Passport-Wireless...ssport+pro
Is this a good idea and will i be able to use it with KODI on IOS? (and leave my laptop behind)
I usually watch Movies / TV shows in 720p or 1080p max.
If anyone else is using this setup and give me suggestion / review.
Regards.,
I do something similar, except in my case I use a RavPower Filehub paired up with a normal WD MyPassport hard drive.
Overall it's a cheaper solution, albeit with two devices rather than one (both fit nicely into an Amazon Basics MyPassport hard case, although mine is the version 2 filehub rather than the later version 3 I linked to above).
For me it's a better solution as it's also an external battery (can power the HD or recharge things) plus a wired/wireless router/bridge and SD card reader too. It shares via DLNA and SMB, so its more flexible (as I can use different drives or USB keys if I want to). The only thing it lacks compared to the MPW is Plex, but from what I know of the MPW it struggles a bit in that role anyway as it's not so powerful a processor in there.
The MP Wireless is a fairly good device if a bit expensive (at least compared to the above) - if you want some user experience and feedback look on the MP Wireless section of the WD forums.
(2016-09-06, 13:05)DarrenHill Wrote: [ -> ]I do something similar, except in my case I use a RavPower Filehub paired up with a normal WD MyPassport hard drive.
I will look into RavPower as well. But can I map it on kodi (ipad) and get all my movies / tv shows syncd? Like I get on my laptop ?
I don't use Apple stuff, so I can't answer from personal experience.
Both methods support DLNA/UPNP streaming, which Kodi can use, and I think both also support SMB (the Ravpower certainly does) which again Kodi can use as a source.
There are a few variations of the Ravpower device out there (there are also some from Hootoo, which are either the same device under a different badge or something very similar) so it's worth doing a bit of background research as there may be offers or other stuff available on given products at given times.
