Full Version: Funimation add-on UK
I have installed the Funimation add-on from within Kodi and as soon as I try and browse the catalogue I get a error message and that I should check the log. Having googled I can't find any recent posts about others having this issue.
So I am beginning to wonder can UK users use the current Funimation add-on (I have a subscription) or is this add-on just pointing at the US?
Looking at the logs it seems to be a authentication error but it is the same details I have used elsewhere, I have tried both my username and email address
22:18:42 T:18446744072565136224 NOTICE: [plugin.video.funimation] _build_request : http://www.funimation.com/feeds/ps/shows...0&offset=0
22:18:42 T:18446744072565136224 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.HTTPError'>
Error Contents: HTTP Error 403: Forbidden
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.funimation/default.py", line 32, in <module>
main()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.funimation/default.py", line 28, in main
nav.list_menu()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.funimation/resources/lib/nav.py", line 38, in list_menu
generate_menu(params)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.funimation/resources/lib/nav.py", line 59, in generate_menu
results = api.get_shows(first_letter=query.get('alpha'))
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.funimation/resources/lib/funimation/api.py", line 30, in get_shows
return self._request('feeds/ps/shows', query)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.funimation/resources/lib/funimation/api.py", line 114, in _request
res = self.http.get(uri, query)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.funimation/resources/lib/funimation/httpclient.py", line 47, in get
return self._request(self._build_request(url))
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.funimation/resources/lib/funimation/httpclient.py", line 63, in _request
content = self.opener.open(request)
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 397, in open
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 510, in http_response
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 435, in error
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 369, in _call_chain
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 518, in http_error_default
HTTPError: HTTP Error 403: Forbidden
22:18:42 T:18446744072498600880 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting plugin://plugin.video.funimation/?get=shows&label=Browse%20Shows
22:18:42 T:18446744072498600880 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.funimation/?get=shows&label=Browse%20Shows) failed
22:18:42 T:18446744072553994272 NOTICE: [plugin.video.funimation] _build_request : https://www.funimation.com/feeds/ps/login.json?v=2
22:18:42 T:18446744072553994272 WARNING: [plugin.video.funimation] login : Login failed for "xxxxx"
Anyone? Or can anyone tell me if the add-on works for them.
This may help, i couldn't find it to try myself
http://addons.kodi.tv/show/plugin.video.funimation/
I noticed last night I got a message on both my Kodi devices that the add-on was now marked as broken.
(2016-09-14, 13:32)Johnny Lager Wrote: [ -> ]This may help, i couldn't find it to try myself
That is the same add-on available in the Kodi repository probably been removed now that is no longer working.
Well I opened Kodi just now before signing up to the forums. I was told Funimation is broken and if I wanted to disable it. I told it No and launched it... Well it still works for me I have a All Access Pass and live in the USA and not using a VPN either.
Edit: I'm now aware that cached info works but its not updating content that is new. Well I hope they fix the problem as I would really like to continue using this app to power watch One Piece. I hate getting up from my couch to switch episodes on my PC every half an hour.
I'm on version 1.2.0.
Edit2: I found this http://www.funimation.com/blog/crunchyro...-to-anime/ Posted by Funimation on 09/08/2016 at 1:00pm This may be the reason it broke.
Thanks for that, just tried to log on and I get a message that says please complete the security check, I guess it's getting stuck on the "click I am not a robot" that Funimation have on their website. Hopeful it won't be long now till there is a proper working add-on.
Well I'm sorry to hear you are having issues still. I just checked I can still watch shows on both apps with out login issues. It must be a UK problem. Anybody else having the same issues.
(2016-09-17, 00:42)J Blog Wrote: [ -> ]Thanks for that, just tried to log on and I get a message that says please complete the security check, I guess it's getting stuck on the "click I am not a robot" that Funimation have on their website. Hopeful it won't be long now till there is a proper working add-on.
Have you tried to log into the website to pass the security check? It sounds like you logged in wrong to many times. If not I suggest logging into the website, then clearing cookies on the app and trying again. Should only be a 1x deal.
Also can you access this link from your logs? http://www.funimation.com/feeds/ps/shows...0&offset=0
If so then it is not a UK issue but an issue with your user
API Was turned down this week, Please see this post
http://forum.kodi.tv/showthread.php?tid=304346
(2017-01-19, 02:03)Protocol-X Wrote: [ -> ]API Was turned down this week, Please see this post
This gives an error that says this thread does not exist.
(2017-01-20, 21:57)J Blog Wrote: [ -> ]
Sorry, it was moved.
http://forum.kodi.tv/showthread.php?tid=304479
