Hello !
First, sorry for my bad english
I have 2 NUC with OpenElec and KODI 16.1 on them.
I have issue with audio with some files. I think KODI don't use "codecs". So, how can i solve this problem please ?
I would point out that i have no problem with these files on my computer.
Thanks in avdance !
Nicodeme.
Really need more info. What issue? What audio setup? What audio codec?
Debug log (wiki) ? Mediainfo output?
(2016-09-10, 01:13)nickr Wrote: [ -> ]Really need more info. What issue? What audio setup? What audio codec? Debug log (wiki) ? Mediainfo output?
Hello !
Issue : video but no audio output. On PC, video & audio output work.
Audio setup : nothing special. NUC pluged on TV via HDMI. Work fine with all other files.
Audio codec : I don't take time to look, but they are MKV, same as other files I use.
Where can i have a debug log please ?
I will test file with Mediainfo.
Click this ->
debug log (wiki) and follow the instructions to gather the log. Then post it to pastebin or some other paste site and post a link to it in this thread.
I will do this as soon as I have time.
Thank you
Mediainfo return : audio MPEG-3.
I don't understand why these files don't play audio on kodi.
I must take time to gather logs...
Have you checked your audio output configuration within your Linux OS? I had a similar issue with Mint 18 (Cinnamon). Kodi's system settings reported the audio output device was a "Pulseaudio" default device. I closed Kodi and took a look at the audio output settings in the OS itself. It looked like it was set to the HDMI digital audio output but I changed it to an analogue output, saved it and then changed it back to the HDMI digital audio output.
Once I started Kodi again, I checked the audio output device once again and it was seeing the same HDMI digital output as the OS. All was well thereafter. Check that.
Thanks you for your response.
I will check but I haven't the problem with all my media, just some
(yes, I am not very quick for response but my time is poor for that at the moment
