Anybody else having this same issue? Could it be Krypton changed the way this button is used? All the other buttons seem to work, just not the back button.
works for me android tv (bravia w800c) latest nightly. never had this issue with any of the betas also.
Are you talking about the actual app? Or your remote control? I'm talking about the "Android TV" app, which is basically the remote on Android.
the remote control. if your using a app maybe its not up to date and compatible with v17.
Yes, I'm referring to the Android TV app. I'm using a Shield TV. I have no physical remote.
It's more than likely they changed how the back button works in V17 since the Android TV app is a global app and the back button works on every other app.
Just tried with Krypton beta1 and spmc.
All fine.
Would you have tinkered with the Kodi key mappings, by any "chance"?
